1990 D250 to W250
Old 05-04-2015, 08:12 PM
  #736
patdaly's Avatar
Looking pretty!
Old 05-04-2015, 08:16 PM
  #737
mknittle's Avatar
Originally Posted by patdaly
Looking pretty!
Thanks Pat.
Old 05-05-2015, 03:56 PM
  #738
mknittle's Avatar
I took the leaking master cylinder and booster off today and made this. It needs a little more work but fits good. Thanks to Alec's sketch on a hydro boost thread, it was real easy.
Old 05-05-2015, 06:06 PM
  #739
Received 1,332 Likes on 862 Posts
I like it! How are you going to make the locator tab? I just picked up a metal plate to make my bracket today as well.
Old 05-05-2015, 06:44 PM
  #740
mknittle's Avatar
I am not sure about the tab yet. maybe file a grove and make a piece then tack weld it in. when I did my Jeep I built up a hump with the wire feed then ground both sides flat and filed the rest to shape.
Old 05-05-2015, 07:06 PM
  #741
That is about what I think I'm going to do. I checked out the mounting plates from the site you posted up in the Hydro boost thread...but the orientation of the HB unit on the cummins trucks is different then the GM units it seems.
Old 05-05-2015, 07:56 PM
  #742
mknittle's Avatar
Too bad the bolt pattern on the first gens is offset.
I didn't bother with the locating key. I may end up with either Dodge or GM.
Old 05-05-2015, 08:13 PM
  #743
mknittle's Avatar
I was pretty interested with this page.
Hydraulic Power Brake Pedal Rods : Tallon Hydraulics, Your Machine Shop!
and this one.
Master Cylinder Push Rods : Tallon Hydraulics, Your Machine Shop!
Old 05-05-2015, 08:27 PM
  #744
Yup saw both those pages as well. I really like the already threaded push rods, and the threaded eyes as well. Could probably come up with a direct push rod swap for our trucks with the parts available on their site.
The problem is the removal of the rod that is staked in there right now. They seem to be a bit of a bear to remove.
Old 05-05-2015, 08:54 PM
  #745
mknittle's Avatar
there is probably some sort of tool that pulls on the rod while holding the socket.
Old 05-05-2015, 09:02 PM
  #746
mknittle's Avatar
Bingo. go to post #29 for some ideas.
1972 Highlander 6.0/4L80E/LoMax - Page 2 - The 1947 - Present Chevrolet & GMC Truck Message Board Network
It looks like the top "H" part is two sleeves with no threads.
Old 05-05-2015, 09:10 PM
  #747
bobva's Avatar
I tried this on a freebie HB off a astro van.
There are 3 indents in the socket tap them out with a worn screwdriver in between the ball&socket the shaft falls right out.
To replace put ball in socket tap indents back in.
Old 05-05-2015, 09:18 PM
  #748
Thanks Bob!!
Guess I'll have to hit the junkyard and see if I can make this method work on a JK piece that I don't have to buy....
Old 05-05-2015, 09:21 PM
  #749
mknittle's Avatar
Cool. That's good to know. If we keep this up we will have so many ways to do this that we may forget what we started to do in the first place choices are good.
Thanks Bob,
Old 05-05-2015, 09:31 PM
  #750
mknittle's Avatar
any way I was looking the guys thread over and he has some cool ideas.
Quick Reply: 1990 D250 to W250
