Need a pcm for a '96 Auto 4x4
Old 03-03-2011, 05:39 PM
ebanezar's Avatar
I am trying to find a pcm for a '96 4x4 Auto. I have replaced everything else that has to do with the tranny and its shifting problems so the pcm is next.
Let me know what you have and a price.
thanks,
Mike
Old 03-03-2011, 05:43 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
My 96 did that and it was the TPS, replaced it and never had another problem you check it yet?
Old 03-03-2011, 05:46 PM
ebanezar's Avatar
I havn't checked that yet, I will check it tomorrow.
My truck is also only charging at 12.9 volts. It has a new alternator and new batteries. So I am thinking I have a problem with the pcm anyway.
Old 03-04-2011, 10:49 AM
infidel's Avatar
Have you checked the engine speed sensor, sometimes called the crank sensor?
PCMs rarely fail, everyone I know who has replaced one now has two good ones.
Mechanics who only know how to diagnose problems with a code reader often blame the PCM on our 12 valves because the reader doesn't tell them anything so they blame the computer.
Old 03-04-2011, 11:40 AM
ebanezar's Avatar
I removed the engine speed sensor and cleaned it. I am running out of options.
Old 03-04-2011, 03:44 PM
gorms's Avatar
Check out "autocomputerexchange.com". Ask for "Gee" if they don't sound like they know what they're talking about. They rebuild PCM's, and I had them rebuild mine when I swapped from auto to manual transmission. Also disabled my EGR information like it was never there. For $250, hard to beat. I don't know how much it would be if you're PCM does indeed have problems, but they sounded reasonable to me. They might be able to give you some more "technical" troubleshooting info too. Maybe bad ground for PCM? Good luck.
Old 03-04-2011, 10:41 PM
ebanezar's Avatar
I checked the TPS today. It checked out at a perfect 1.2v at idle to 4.4v full throttle.
I am lost.
Old 03-04-2011, 11:20 PM
Admin Team Leader
I am lost.
How did it read as you slowly swept the range? was it bouncy and jittery? It may read perfect at both ends but the contacts can be worn in the middle where you normally operate it. I took my old one apart and you could clearly see the worn contacts in the middle but both ends of the range looked new.
Old 03-04-2011, 11:35 PM
ebanezar's Avatar
It was smooth all the way up to full throttle. I am thinking of taking it to a tranny shop on Monday.
Big Perm
12-18-2007 08:44 PM
V.R.Wheeler
08-04-2007 01:00 PM
lews930
03-07-2007 06:33 PM
DustyRock
11-27-2004 04:38 PM
Quick Reply: Need a pcm for a '96 Auto 4x4
