Wiring HELP!
Wiring HELP!
Attempted a crew cab build for the last few weeks. Got drivetrain switched over, & even started. Used engine & wiring harness from the '89 donor, into an '84 W350 srw. Had it started last week, but no gauges or dash lights, signals, or tail lights. Does anyone have a schematic they could pass on to help. I imagine I have a ground issue, among other things, but without some map it looks like spaghetti to me. Thanks in advance!
did you swap the inside wiring also ? everything from Donor will swap right over makes it alot easier .Also there are a few ground wires under dash that have to be hooked up to make thing's work right. send me a PM with your e mail address theses truck's are really easy to do .
We did use the interior harness as well, however it was pretty well dismembered after the previous owner. It's likely in the process of cleaning up & deciphering what was what, that we mislabeled or just lost connections...The truck still starts & runs though!
wyododge
Jan 13, 2009 02:25 AM
charcoal600
Apr 30, 2005 02:34 PM
Hummin Cummins
Mar 24, 2003 07:41 AM
