VE rebuild with pics Look inside
Old Dec 29, 2008 | 04:21 AM
  #61
Benjamin b2's Avatar
where did you get the triangle looking socket thats made by bosch? did you homebrew it or buy it somewhere?
Old Aug 16, 2009 | 02:15 PM
  #62
PapeCAT's Avatar
Old Aug 16, 2009 | 02:33 PM
  #63
I haven't seen 545 on here in a while.
Old Aug 16, 2009 | 02:57 PM
  #64
PADuallyBoy's Avatar
Can't wait for the finished product, new paint looks like it adds some horsepower! Makes me wanna overhaul mine.
Old Aug 16, 2009 | 09:57 PM
  #65
bgilbert's Avatar
Craftsman 12 point 13mm socket will fit with a little love tap from a hammer, without any grinding inside the socket.
Old Aug 17, 2009 | 12:34 AM
  #66
PapeCAT's Avatar
thx billgilbert... I ended up using a gator universal type socket for the aft dv side triwing fitting....
Old Aug 17, 2009 | 12:55 AM
  #67
Jim Lane's Avatar
You can get the socket from here, although I have not ordered one yet.
Jim
http://www.dieselvw.com/3SidedSpecialTool.htm
http://www.dieselvw.com/QuantumParts.htm
Old Dec 6, 2010 | 10:00 AM
  #68
Subliminal's Avatar
Man, what a bummer...I was really hoping this thread would keep going.
Definitely appreciate the write up...but I need closure!
Old Dec 6, 2010 | 10:13 PM
  #69
1stGen545's Avatar
going on 3 years later but im about to build another and will try to finnish it up.
Old Feb 20, 2011 | 08:16 AM
  #70
that_guy's Avatar
I really appriciate this thread. I keep looking back to it. I'm rebuilding my I right now and have used your pictures to see what goes where and how it should be. Thanks a million guy.
Old Sep 1, 2011 | 09:58 PM
  #71
BearKiller's Avatar
Jim
I can't get these links to connect anymore.
By the way, THANKS again 1stGEN545 for all the pictures and instructions.
Old Sep 2, 2011 | 01:29 PM
  #72
BearKiller...here the link to the sticky and what I did to get those 3 sided bolts out...cheap and easy.
https://www.dieseltruckresource.com/...ml#post2822314
Old Sep 2, 2011 | 02:34 PM
  #73
Jim Lane's Avatar
I found this place although it might might a little extra time to get here.
http://www.dieselkontor.de/index.php
http://www.dieselkontor.de/product_i...roducts_id=200
I know nothing about this company..
Some have cut down a 13-MM socket using a dremel to make an appropriate socket fit.
I am going to have my brother in law try and make me a socket at his machine shop, should be simple to cut 3 points off from a socket using a mill.
Sorry about the broken link.
Jim
Old Sep 2, 2011 | 10:42 PM
  #74
BearKiller's Avatar
THANKS, JIM LANE and thrashingcows.
I can't for the life of me remember what brilliant trick I used when we did the son's pump.
Seeing as how I have my pump stripped down and ready to pull off the engine in the morning, I will use that bent cotter-pin trick.
I may also either buy or machine an actual proper socket.
What would be wrong with grinding a normal HEX on those bolt-heads, once they are out ??
Old Oct 11, 2011 | 10:29 PM
  #75
thumpertrev's Avatar
Need more please!!
