Check out chickenfarmer's Dodge!
Old 10-23-2014, 10:49 AM
chickenfarmer's Avatar
Hello everybody! Of course I don't know where this goes, but I just wanted to show off my new w250 to y'all. It's a 93 w250 cummins. Pretty stock with only 137 thousand on the od. If anyone wants to read I'd be happy to tell you all about it. I'm working on getting rid of all the fusible likes and putting in a fuse box now and I will give a write up on it later. It needs some work and some love and it will be an awesome truck, let me know if you want to hear more!
Old 10-23-2014, 12:03 PM
mknittle's Avatar
Welcome to the board. You are in the right place. Now that you have started a build thread we will be watching A word of warning though we like pictures.
Your truck looks like a good start. what are your plans for it?
Old 10-23-2014, 01:14 PM
1STGENFARMBOY's Avatar
If you don't post pictures like Mknittle said........you will be DEAD to us.
Old 10-23-2014, 01:27 PM
Perfect, I like pictures too! Once I get wiring done and a few little maintenance things it will hit the salty michigan roads for winter. I won't do too much to it, I'll get a pic under the hood when I get home Tonight
Old 10-23-2014, 01:28 PM
I am on the hunt for an earlier style grill to mount up on it, and I bought a set of factory rims off an '08 to really make it look sharp for next summer.
Old 10-23-2014, 02:55 PM
mknittle's Avatar
There is a bit more work to get the older grille to fit than just a bolt on. That said I like the older grilles better.
Did you see this thread? I like the way it came out.
https://www.dieseltruckresource.com/...9-t319515.html
Old 10-23-2014, 03:33 PM
aicomp's Avatar
Looking forward to seeing your project progress.
Mike
Old 10-23-2014, 06:04 PM
I did see that grill thread, and I think it will be worth the work, I want the old girl to match my trailduster.
Here's the under the hood pic as promised. 0
The pumps turned up a little but I haven't looked inside it yet. I got a full 4" strait pipe from the turbo back. I just got the bhaf on and I do plan on building a nice box for it hopefully sooon. I'm glad you guys are interested! I'm enjoying my first oil burner!
Old 10-23-2014, 06:51 PM
sherod's Avatar
Keep 'em coming! Welcome to the gang!
Old 10-23-2014, 06:58 PM
mknittle's Avatar
Mike
Same here.
Old 10-23-2014, 07:02 PM
mknittle's Avatar
Looks like you are on the right track.
Old 10-23-2014, 07:06 PM
Originally Posted by mknittle
Same here.
Well I'm glad you guys are wanting more! I'll keep letting you know what's going on with it, hopefully I'll get the wiring mess figured out this weekend
Old 10-23-2014, 07:33 PM
mknittle's Avatar
Ya gotta wonder what the Chrysler engineers were thinking when it comes to wiring.
There are some good articles in the "sticky" section of this board on adding relays to take the load off the stock wiring.
At some point I am going to re place the fusable links with maxi fuses.
Old 10-23-2014, 10:07 PM
peckens's Avatar
Same here, I have about a bag full of them from the junkyard. Those suckers aren't cheap from the store lol.
Old 10-24-2014, 12:29 AM
Received 1,332 Likes on 862 Posts
Looks like you have a decent truck to start with there, and a good attitude!
I'd spend a few minutes pressure washing under the hood. Try and get the motor and surrounding areas as clean as possible. I like to clean with straight water first, then I use Simple Green...spray it over everything, let it set up for 10 minutes of so, then start spraying again. Usually comes out pretty well.
Looking forward to your updates.
Quick Reply: Check out chickenfarmer's Dodge!
