Review of Interco Trxus MT
Old 01-08-2005, 06:08 PM
RadRam's Avatar
I ran the 33x12.5x17 on my truck when it was new - We went thru 8 tires to get 4 that balanced without a major amount of wts. Heavy tire ! fairly quit on the hwy wore well, actually good ice traction. The only thing I did not like was every time the truck sat for a day or more - the truck vibrated bad till i drove for awile then they would calm down - Excellent traction.
Old 01-08-2005, 06:50 PM
quantrill88's Avatar
I couldnt agree w/ you more the Trxus'. I had a set on my 2000, great (for a diesel) offroad but give the truck some odd handling onroad. And def. not the best highway tire.
Overall I wasnt pleased w/ mine (mainly due to the mileage, or lack thereof) but then again, given the highway miles I put on them Im not sure many other MTs wouldve done better
Glad you like yours
Jeff
Old 01-08-2005, 08:00 PM
Kyle Graham's Avatar
Yah I have had a couple of sets of them in the past they arent made for on road use really soft rubber and a heavy Diesel truck is not a good combo best advice is rotate often you will notice fronts will began to cup from braking all the weight in transfer causes this. When I rotate I would take the fronts left and right swap them around left to right and put them on rear so the cupping would even out so the tire will last longer wearing evenly. I was able to get 30k out of them that in my opinion is alot for a m/t. Tires are extremely durable drove on many construction sites where nails are everywhere never once did I have a flat first tire I have ever owned that didnt end up with a flat.
Old 01-09-2005, 05:44 PM
hovisimo's Avatar
i had 285/75/16 trXus on my old truck, streetable for a MT but i would not run them on this truck because of the speeds it sometimes sees. i've found if you need serious offroad performance, a set of TSLs or similar swampers mounted on steel wheels is the way to go, just throw them on when needed. the trXus is a decent compromise for >70mph daily driving, though.
Old 01-09-2005, 05:53 PM
Patrolman808's Avatar
I like mine. I've had them on the truck for a year and a half and probably 25k miles. They are wearing pretty well for me. I just run a good bit more air in the fronts. If they made them in 37's I'd like them even better.
VikingDiesel
16
12-12-2006 05:22 PM
CumminsRedneck
17
12-11-2006 12:33 AM
VikingDiesel
18
12-01-2006 09:43 PM
VikingDiesel
Off Road / 4x4
30
08-16-2006 10:08 AM
Topper
03-17-2006 06:26 PM
Quick Reply: Review of Interco Trxus MT
