Quad Adrenaline Beta Testing....
Old Dec 13, 2007 | 09:58 PM
  #271
J Lent's Avatar
Originally Posted by 1-5-3-6-2-4
you have to add another {e} at the end of the file name so it ends with .exe or the computer won't recognize it as a program
I tried that in different ways with no luck. I clicked on ex_file at the bottom & tried double clicking it etc. I also tried clicking on it & hitting F2, but nothing will let me type in the box. Any ideas?
Old Dec 13, 2007 | 10:09 PM
  #272
1-5-3-6-2-4's Avatar
you'll have to save it to your harddrive first then rename it, then execute it.
Old Dec 13, 2007 | 10:10 PM
  #273
J Lent's Avatar
I'll try that, Thanks
Old Dec 13, 2007 | 10:19 PM
  #274
J Lent's Avatar
Doesn't work? I saved to desktop & it only lets me rename the software, but won't let me change to exe.
Old Dec 13, 2007 | 10:37 PM
  #275
voyles's Avatar
Lent,
1. save it to a folder,
2.In that place you saved it go under the tools option(Right beside the help button),
3. Scroll to under folder options, click it
4. Click the tab button that says view(beside general tab)
5. Scroll down in the settings thats listed to the one that says hide extensions for known file types. remove the check in that box
6. Now you can right click quads file and select rename or properties to change the exe.
7. now open the file, click update module, it will list searching, now plug in your box(USB cable) at that time for it to read it.
Hope I helped
John V
Old Dec 14, 2007 | 02:39 PM
  #276
J Lent's Avatar
Got it figured out, Thanks guys.
Old Dec 14, 2007 | 06:56 PM
  #277
scottsjeeprolet's Avatar
So when is it going to be for sale to the general public?
Anyone wanna buy my Comp? I'm sure they will be plentiful in the classifieds soon.
Old Dec 15, 2007 | 12:55 PM
  #278
1BAD4X4's Avatar
WILL be? They ARE!
Old Dec 15, 2007 | 01:40 PM
  #279
dodgediesel's Avatar
Any new programs to play with Qzilla? This rough idle I have is killind me?
Old Dec 15, 2007 | 02:41 PM
  #280
J Lent's Avatar
I'm running the software from quads website & when the truck is running while in TT mode [key shut off] I am hearing the engine stumble, sometimes it will idle up/down. Anyone else getting this stumble? It also does it when I start my truck in the morning.
Old Dec 15, 2007 | 03:19 PM
  #281
J Lent, if you don't mind, could you help try something out? With my truck, when I manually (with a stick or my manual high idle switch) idle my truck at 1200 rpm and switch from PL00 to PL01-PL10, I have a horrible stumble/idle. Kinda like the truck's trying to fuel early or something. I don't know if it's my setup or a glitch in this Adrenaline box? No one else testing has this issue going on. I'm wondering if you might be having the same issue as I am?? It's like a hammering and it is highly noticable on anything from PL01-PL10 but not on PL00 and seems to be around 1100-1300. You can even notice it driving around around those rpm's and I'm guessing it can't be good for my VP44 or Mach 4's??? Just don't want to damage my stuff!! Thanks a bunch for the help.
Jamie
Old Dec 15, 2007 | 03:36 PM
  #282
J Lent's Avatar
dodgediesel, I have noticed this & told Justin at Qzilla about it & they are working on a fix. My truck also does it switching from PL00 to PL01, but not as noticeable from 01 up unless like you said it is at mid rpm switching levels.
Old Dec 15, 2007 | 04:02 PM
  #283
I video taped it and sent it to Justin. Thanks bud, now I know I'm not crazy!! Did they tell you they have a fix for it???
Old Dec 15, 2007 | 04:31 PM
  #284
J Lent's Avatar
Just said that they are working on it & he sent me a file to try, but it wasn't fueling.
Old Dec 15, 2007 | 04:52 PM
  #285
I see. I wonder if all the previous Adrenaline files do this too??? I just leave mine on PL00 until something else new comes out.
