Ok, lets do our dana 60 4x4 king pins
Old 05-25-2011, 08:58 PM
maybe368's Avatar
Talking Ok, lets do our dana 60 4x4 king pins
Ok. following the Thrashingcows lead, I thought to add this on the first page of this thread in case it vaporizes or gets attacked by a zombie apocalypse:
https://web.archive.org/web/20170702...g-pins-290373/ ...Mark
Ok guys and gals, I decided to do a how to thread on replacing your Upper king pin and renew all of the bushings and seals on a 4x4 dana 60 for our Dodges. I am working alone and had nobody to take pics, so I did not take any disassembly pics. I didn't want to get my camera dirty. This will be an assembly thread, but all you need to do is start at the bottom and reverse this for disassembly.
I did mine one side at a time, but you could raise the whole front and do both sides at once. Always use safe practices, like eye protection and good, sturdy jack stands. NEVER GET UNDER A VEHICLE SUPPORTED BY A JACK ALONE. I am only going to talk about the work from after the removal of the hub and disc assembly. This is covered in a great BC847 thread in the sticky Here https://www.dieseltruckresource.com/...d.php?t=143024.
Now that I talked about how to start, now I am going to jump to the other end and talk about the install. Just reverse this for disassembly.
Make sure that all parts are clean and ready for installation,
http://www.flickr.com/photos/63170901@N03/5760330840/http://www.flickr.com/photos/63170901@N03/5760330840/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Makes sure that the lower king pin bearing cup seat is clean and ready to accept the new bearing cup:
http://www.flickr.com/photos/63170901@N03/5760332176/http://www.flickr.com/photos/63170901@N03/5760332176/ by http://www.flickr.com/people/63170901@N03/, on Flickr
During disassembly, the old bearing cup needs to be driven out, but retain the old cup for use during reassembly. I hit the lower cap from the top with a hammer to start the cup moving, then used a stout punch to drive it out.
Remember to put the cap in first:
http://www.flickr.com/photos/63170901@N03/5759788755/http://www.flickr.com/photos/63170901@N03/5759788755/ by http://www.flickr.com/people/63170901@N03/, on Flickr
then the bearing cup:
http://www.flickr.com/photos/63170901@N03/5760332070/http://www.flickr.com/photos/63170901@N03/5760332070/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Tap the cup in as evenly as possible. If you have the correct drift, use that, but carefully tapping works:
http://www.flickr.com/photos/63170901@N03/5760332472/http://www.flickr.com/photos/63170901@N03/5760332472/ by http://www.flickr.com/people/63170901@N03/, on Flickr
You can use the old cup to fully seat the new cup, but be sure to put the thicker side down (very important):
http://www.flickr.com/photos/63170901@N03/5760332558/http://www.flickr.com/photos/63170901@N03/5760332558/ by http://www.flickr.com/people/63170901@N03/, on Flickr
The old cup will be stuck No worries, clamp a pair of vise grips on the thick side of the old cup and drive off with a hammer:
http://www.flickr.com/photos/63170901@N03/5760332788/http://www.flickr.com/photos/63170901@N03/5760332788/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Works every time:
http://www.flickr.com/photos/63170901@N03/5759789329/http://www.flickr.com/photos/63170901@N03/5759789329/ by http://www.flickr.com/people/63170901@N03/, on Flickr
I then used a punch to make sure it was well seated. You can now use the old cup to drive in the new seal. Put the freshly packed lower king pin bearing, after greasing the cup, then the seal. Drive it in until it firmly seats:
http://www.flickr.com/photos/63170901@N03/5759789475/http://www.flickr.com/photos/63170901@N03/5759789475/ by http://www.flickr.com/people/63170901@N03/, on Flickr
this is getting long, so I am going to post this and continue in a reply
Old 05-25-2011, 09:10 PM
maybe368's Avatar
Continuing with lower:
http://www.flickr.com/photos/63170901@N03/5759789551/http://www.flickr.com/photos/63170901@N03/5759789551/ by http://www.flickr.com/people/63170901@N03/, on Flickr
http://www.flickr.com/photos/63170901@N03/5759789625/http://www.flickr.com/photos/63170901@N03/5759789625/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Lower bearing and seal all done:
http://www.flickr.com/photos/63170901@N03/5759789759/http://www.flickr.com/photos/63170901@N03/5759789759/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Upper king pin installation and disassembly tools:
http://www.flickr.com/photos/63170901@N03/5760333546/http://www.flickr.com/photos/63170901@N03/5760333546/ by http://www.flickr.com/people/63170901@N03/, on Flickr
http://www.flickr.com/photos/63170901@N03/5759790215/http://www.flickr.com/photos/63170901@N03/5759790215/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Apply blue locktight to threads on new upper king pin (edit: I wanted to be sure and I find that red locktight is recommended on the pin, so use red locktight hereMark):
http://www.flickr.com/photos/63170901@N03/5760333820/http://www.flickr.com/photos/63170901@N03/5760333820/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Thread it in, mine seated by hand:
http://www.flickr.com/photos/63170901@N03/5759790431/http://www.flickr.com/photos/63170901@N03/5759790431/ by http://www.flickr.com/people/63170901@N03/, on Flickr
http://www.flickr.com/photos/63170901@N03/5759790567/http://www.flickr.com/photos/63170901@N03/5759790567/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Put the hex wrench in and drive it in with a hammer:
http://www.flickr.com/photos/63170901@N03/5759790655/http://www.flickr.com/photos/63170901@N03/5759790655/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Continued...
Old 05-25-2011, 09:22 PM
maybe368's Avatar
place big breaker and hex socket:
http://www.flickr.com/photos/63170901@N03/5760334240/http://www.flickr.com/photos/63170901@N03/5760334240/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Place super long cheater, this one is 8' made of 1.5" square tubing with 1/4" wall thickness:
http://www.flickr.com/photos/63170901@N03/5759790823/http://www.flickr.com/photos/63170901@N03/5759790823/ by http://www.flickr.com/people/63170901@N03/, on Flickr
This is how far it tightened:
http://www.flickr.com/photos/63170901@N03/5759791013/http://www.flickr.com/photos/63170901@N03/5759791013/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Remove hex with vise grips and hammer. PB Blaster and heat may be necessary:
http://www.flickr.com/photos/63170901@N03/5759791117/http://www.flickr.com/photos/63170901@N03/5759791117/ by http://www.flickr.com/people/63170901@N03/, on Flickr
All done:
http://www.flickr.com/photos/63170901@N03/5759791197/http://www.flickr.com/photos/63170901@N03/5759791197/ by http://www.flickr.com/people/63170901@N03/, on Flickr
grease king pin:
http://www.flickr.com/photos/63170901@N03/5760334978/http://www.flickr.com/photos/63170901@N03/5760334978/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Hang knuckle on upper pin:
http://www.flickr.com/photos/63170901@N03/5759791587/http://www.flickr.com/photos/63170901@N03/5759791587/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Place seal with opening up:
http://www.flickr.com/photos/63170901@N03/5760335294/http://www.flickr.com/photos/63170901@N03/5760335294/ by http://www.flickr.com/people/63170901@N03/, on Flickr
http://www.flickr.com/photos/63170901@N03/5759791971/http://www.flickr.com/photos/63170901@N03/5759791971/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Continued:
Old 05-25-2011, 09:34 PM
maybe368's Avatar
Use a blunt object to seat the seal in the bottom:
http://www.flickr.com/photos/63170901@N03/5760335404/http://www.flickr.com/photos/63170901@N03/5760335404/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Grease the upper bushing, note the tab on the bushing for placement:
http://www.flickr.com/photos/63170901@N03/5759791749/http://www.flickr.com/photos/63170901@N03/5759791749/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Place the bushing with the tab located in the slot in the knuckle:
http://www.flickr.com/photos/63170901@N03/5759791809/http://www.flickr.com/photos/63170901@N03/5759791809/ by http://www.flickr.com/people/63170901@N03/, on Flickr
place gasket:
http://www.flickr.com/photos/63170901@N03/5760335470/http://www.flickr.com/photos/63170901@N03/5760335470/ by http://www.flickr.com/people/63170901@N03/, on Flickr
place spring retainer:
http://www.flickr.com/photos/63170901@N03/5760335564/http://www.flickr.com/photos/63170901@N03/5760335564/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Place spring:
http://www.flickr.com/photos/63170901@N03/5759792285/http://www.flickr.com/photos/63170901@N03/5759792285/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Locktight bolts:
http://www.flickr.com/photos/63170901@N03/5760335784/http://www.flickr.com/photos/63170901@N03/5760335784/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Place upper cap, but leave bolts loose for now:
http://www.flickr.com/photos/63170901@N03/5759792511/http://www.flickr.com/photos/63170901@N03/5759792511/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Continued:
Old 05-25-2011, 09:42 PM
maybe368's Avatar
lube lower king pin and locktight bolts:
http://www.flickr.com/photos/63170901@N03/5759792625/http://www.flickr.com/photos/63170901@N03/5759792625/ by http://www.flickr.com/people/63170901@N03/, on Flickr
place lower king pin:
http://www.flickr.com/photos/63170901@N03/5759792697/http://www.flickr.com/photos/63170901@N03/5759792697/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Tighten evenly and torque to 70 to 90 foot lbs:
http://www.flickr.com/photos/63170901@N03/5759792803/http://www.flickr.com/photos/63170901@N03/5759792803/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Evenly tighten the upper cap bolts:
http://www.flickr.com/photos/63170901@N03/5760336300/http://www.flickr.com/photos/63170901@N03/5760336300/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Torque to 70 to 90 foot lbs:
http://www.flickr.com/photos/63170901@N03/5760336392/http://www.flickr.com/photos/63170901@N03/5760336392/ by http://www.flickr.com/people/63170901@N03/, on Flickr
At this point you can reconnect the tie rod end to the knuckle.
Continued:
Old 05-25-2011, 09:59 PM
maybe368's Avatar
Now to prepare spindle and axle shaft:
http://www.flickr.com/photos/63170901@N03/5760331684/http://www.flickr.com/photos/63170901@N03/5760331684/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Thoroughly lubricate the spindle needle bearing, inside the spindle and place the seal with the open side out (away from needle bearing):
http://www.flickr.com/photos/63170901@N03/5759789859/http://www.flickr.com/photos/63170901@N03/5759789859/ by http://www.flickr.com/people/63170901@N03/, on Flickr
http://www.flickr.com/photos/63170901@N03/5759789965/http://www.flickr.com/photos/63170901@N03/5759789965/ by http://www.flickr.com/people/63170901@N03/, on Flickr
lubricate shaft:
http://www.flickr.com/photos/63170901@N03/5760336498/http://www.flickr.com/photos/63170901@N03/5760336498/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Place spacer an shaft with the bevel towards the u-joint. Lubricate the inside of the larger seal and place it on the shaft:
http://www.flickr.com/photos/63170901@N03/5760331796/http://www.flickr.com/photos/63170901@N03/5760331796/ by http://www.flickr.com/people/63170901@N03/, on Flickr
http://www.flickr.com/photos/63170901@N03/5760331862/http://www.flickr.com/photos/63170901@N03/5760331862/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Slide the hub onto the shaft:
http://www.flickr.com/photos/63170901@N03/5760331962/http://www.flickr.com/photos/63170901@N03/5760331962/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Put antiseize compound on axle shaft flange:
http://www.flickr.com/photos/63170901@N03/5760336598/http://www.flickr.com/photos/63170901@N03/5760336598/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Install shaft, It only goes on 1 way:
http://www.flickr.com/photos/63170901@N03/5759793219/http://www.flickr.com/photos/63170901@N03/5759793219/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Continued:
Old 05-25-2011, 10:10 PM
maybe368's Avatar
Install The caliper support and brake shield, locktight the threads and torque the nuts to 50 to 60 foot lbs:
http://www.flickr.com/photos/63170901@N03/5760336780/http://www.flickr.com/photos/63170901@N03/5760336780/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Here you need to install the rotor/hub assembly, caliper, brake pads and 4x4 hub assembly, see sticky for instruction on this:
http://www.flickr.com/photos/63170901@N03/5760336878/http://www.flickr.com/photos/63170901@N03/5760336878/ by http://www.flickr.com/people/63170901@N03/, on Flickr
This is a pic of my old, right, upper king pin. You can see the unusual wear:
http://www.flickr.com/photos/63170901@N03/5760331148/http://www.flickr.com/photos/63170901@N03/5760331148/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Here is a pic of the springs and how worn and compressed they are:
http://www.flickr.com/photos/63170901@N03/5759787957/http://www.flickr.com/photos/63170901@N03/5759787957/ by http://www.flickr.com/people/63170901@N03/, on Flickr
I hope this helps anyone attempting this job, it is very rewarding and nothing feels better than having a good suspension under you ...Mark
Old 05-25-2011, 10:56 PM
Fibrestar's Avatar
Great write up, Doesn't look that scary now. Thanks
Old 05-25-2011, 11:00 PM
maybe368's Avatar
Thanks, I was very worried about this job, but it was not as bad as I thought, one just needs to apply a little pressure via large tools...Mark
Old 05-26-2011, 02:23 PM
maybe368's Avatar
When I cleaned up the right side parts I found that the bushing had failed completely and was no longer supporting the spring evenly. This is demonstrated by the deformation of the steel spring retainer. This side is much worse than the other and I hope that this was the cause of my death wobble problem.
http://www.flickr.com/photos/63170901@N03/5762225375/http://www.flickr.com/photos/63170901@N03/5762225375/ by http://www.flickr.com/people/63170901@N03/, on Flickr
Mark
Old 05-26-2011, 04:22 PM
1st Generation Admin
BC847's Avatar
Stuck.
Old 05-26-2011, 04:28 PM
maybe368's Avatar
Originally Posted by BC847
Stuck.
Cool, I feel honored, Thanks Mark
Old 05-27-2011, 04:33 PM
92'1stGen's Avatar
Very nice. I'll be starting on this this weekend.
Old 05-27-2011, 07:12 PM
maybe368's Avatar
Thanks, I got to checking and I found lower king pins here: https://www.wfoconcepts.com/cr/Dana-60/3172 and have 2 of them ordered up. I am going to replace them with the wheel still on, just jacked up. I thought they were not available any more. When I get them, I will post the pics. I am not going to drive the truck until EVERYTHING is new...Mark
Old 05-27-2011, 11:57 PM
farmer0_1's Avatar
nice work takes all the mystery out of it. thanks
Quick Reply: Ok, lets do our dana 60 4x4 king pins
