Ok to drive with t-stat stuck open?
Old Feb 7, 2011 | 02:46 PM
zgoober's Avatar
Pretty sure my thermostat has been stuck open for the past 3 months. Truck doesn't get above ~150 degrees.
Has this, or will this, have any negative side effects? Major or minor?
Old Feb 7, 2011 | 03:04 PM
67HotRod's Avatar
Besides lower mpg, I could see carbon buildup..
Old Feb 7, 2011 | 03:23 PM
SIXSLUG's Avatar
I changed mine out as soon as I noticed my temps were below normal.
Old Feb 7, 2011 | 05:44 PM
carl48's Avatar
more engine wear
Old Feb 7, 2011 | 09:44 PM
m.t.hands's Avatar
the "seal" broke on mine and was holding it open, takes all of ten minutes to change it out....i went with a napa, but i think most suggest finding a cummins replacement....
Old Feb 8, 2011 | 08:07 AM
zgoober's Avatar
Yes, I have replaced the thermostat.
I can find information about thermostats failed closed and the I'll effects of overheating. I can't find much about failed open. At least nothing specific...
Carbon build up? Where? Is that serious?
Engine wear? Why? Where?
Old Feb 8, 2011 | 08:48 AM
rickf's Avatar
One of the byproducts of combustion is sulfur dioxide, not as much now with USD but still there. When mixed with the condensation in an engine you get sulfuric acid. I don't think I need to say that is bad. When an engine does not get above 180 degrees then the water does not evaporate out of the crankcase and you have the acid formation. Plus diesels run better the hotter they are.
Rick
Old Feb 8, 2011 | 10:02 AM
m.t.hands's Avatar
i would think you'd experience incomplete and poor cumbustion, leading to higher carbon deposits in the valve-train
Old Feb 8, 2011 | 12:54 PM
zgoober's Avatar
Thanks. Good information to know, but not so great to hear. Will running any additive in the fuel or oil clean this up?
Old Feb 8, 2011 | 01:07 PM
ellerman's Avatar
Zgoober, change the thermostat and if you are worried about an excessive amount of acid that could have built up change your oil. If you are worried about carbon run the truck hard or tow something heavy. I doubt you did any damage.
Old Feb 8, 2011 | 04:30 PM
gator_grabber's Avatar
I'd highly suggest you attempt to get a Cummins thermostat, the aftermarket ones just don't perform as well. BTW, running an engine too cold is really hard on it and causes accelerated wear.
Old Feb 9, 2011 | 08:08 PM
totalloser's Avatar
+1 to cummins stat. Usually fails open. This is pretty rare with normal stats. Opens abruptly causing temp fluctuations, but has much bigger port.
IMO the main issue is the terrible fuel efficiency. But as to unhappy engine from running cold, the pistons will never get to op temps, and will remain tapered instead of swelling up to fill the bore. Potentially a little more wear on pistons, but I wouldn't worry much about it.
You are probably losing about 3mpg running at that temp. Add it up... ouch!
Old Feb 10, 2011 | 02:11 PM
Midnite's Avatar
Zgoober, I guess I'll be the lone dissenter here. I don't think you've suffered any engine damage whatsoever. I also don't believe the mileage difference is much at all, at least in my experience with a failed thermostat. It certainly wasn't noticeable in my case.
It's not like the engine is remaining at the same temperature as the surrounding environment. Even with a failed thermostat the engine gets up to 100 degrees fairly quickly, it just starts to taper off and take progressively longer to reach higher temps.
Baja
Jan 29, 2008 08:17 PM
Desert Diesel
Mar 18, 2007 08:53 PM
Cowhand
Aug 21, 2004 01:10 PM
chromedome
May 9, 2004 10:24 PM
Crazy Horse
Nov 16, 2002 01:00 AM
