Lope
Old Mar 17, 2013 | 09:54 PM
Ram_SRT-10's Avatar
Lope
I replace the cracked 53 in my 01 with a new used engine my 53 never lope and neither did the new motor in the truck it came out of when i swapped the engine i took my 75 hp injectors and hotrod pump of the 53 block and put them on the new engine replacing the injector seals but not the crossover seal as i got the wrong ones in the kit anyhow now the truck has a lope to it anyone have any ideas why?
Old Mar 18, 2013 | 02:11 AM
RacerRon's Avatar
Mine did the lope when one of my injector tubes was not fully seated in the injector. Apparently I had a partially dead cylinder and could not tell. I finally found it after a few years of looking for a fuel leak I thought I had due to the ocassional fuel smell. One of the injector nuts was dusty from the slightest fuel leak that was never wet. Once I re-torqued it the tube popped in and lope is gone.
Sent from my DROID RAZR using Tapatalk 2
Old Mar 18, 2013 | 06:22 AM
high bid's Avatar
Make sure all the inj lines are good and tight...a loose line could cause this. Had the same issue when replacing inj.
Old Mar 18, 2013 | 11:16 AM
Ram_SRT-10's Avatar
Alright i will retorque all the injector lines and see what happens
Old Apr 22, 2013 | 07:09 PM
Ram_SRT-10's Avatar
what had been causing my lope was I didn't have my second battery in and had went to copper lug style terminals so my pcm was not grounded properly
Old Apr 23, 2013 | 06:11 AM
high bid's Avatar
Glad you found it
Satan's Chariot
Jul 11, 2006 02:50 PM
nagel
Jul 4, 2006 10:29 PM
SoTexRattler
Mar 14, 2005 10:28 AM
crossy
Oct 15, 2004 09:58 PM
dodgeman01
13
Apr 8, 2003 12:50 PM
