gauges
gauges
Ok before I do any mods I want to install gauges so I have a stock base line.
What/who/where has a good set of guages and mounts for a 09 6.7 ?
Are there plug and play available ?
gordy
gordy
I hate to say but im still old fashion and in love with my autometer phantom guages. Go to ebay and pickem up.Im not much for the whole electronic monitors although they read more things for less money, but thats something youd have to decide. Also is your truck a auto... You might want to add that in your sig.
I will agree with soot that the standard gauges are definitely a better option, but at a much higher cost.
All depends on what you want to do.
I have the EJA cause it was the best option at the time for the deletes. Now that the Smarty is here, and my buildup progresses I will eventually replace it with Isspro gauges. Looking to go with EGT, Boost, Trans temp, fuel and rail pressure.
gauges
What I'm wanting is exhaust & trans temp mostly. I'm not really wanting to hot rod the truck just make it get the most mpg and still run as strong as it does at stock maybe just a tad more. If I understand all this stuff those 2 things are the ones that you need to keep and eye on ?
thanks
gordy
thanks
gordy
Sounds like the Insight might be just up your ally. I believe it does fuel pressure too.
Id moniter the EGT, Boost, Tranny temp, and FP with it. Just my two cents.
Listing might not be out for a 2009, but check 2008 or 2007 with the 6.7L as this should be the same.
probe
X2, that is why I went that route. Installed the EGT probe and I've barely scratched the surface of what it can do/report. Can't beat the real gauges if you have the time and money as they are a step up, but the Insight is a nice little package.
Where's the best place to install it ?
thanks
I installed mine in the collector. Edge has pretty good pics showing the proper place to install it.
A right angle drill is a must. It helps to remove the turbo coolant lines too for a little extra wiggle room. Its a tight work area.
Take your time and work slow. Worm and I did mine, it drilled it fine, but we broke the tap off in the manifold.
Exceeded the safe working limit of beer that night... Pucker factor went through the roof for a bit, 6.7 manifolds arnt cheap. The next day had to drive it around for 20 mins or so, heat it up, and used a punch and a chisel to work it out. Backed out as pretty as you please, finished with a new tap and everything else went smooth.
Which plate did you use. I would rather mine be in the collector. You wont have a skewed reading from just one cylinder that way.
You have to drill and tap it yourself.
insight
Ok the ETG probe goes in the collector how about the trans temp how is it conected to the Insight, with a electronic sender from the pan, or does it have a probe/lead that goes all the way to the insight from the pan ? And what else can it monitor? The web says it montiors a lot of stuff but there's no listings of what it can do. Thanks again !
