where to find a 14cm wg housing?
other than the classifieds here, where's a good spot to look for used exhaust housings?
I need a 14cm wg housing for a '94 12V...
Thanks.
Greg
Thanks.
Greg
Originally Posted by northslope
Keep an eye on e-bay, I've seen them there a few times
I've done that a few times...
main problem for me is they sometimes post actual part numbers, and I have no idea what they mean...
if it actually said 14cm housing for a WHC1 or HX35, I could figure that much...
Greg
TURBINE HOUSING CASTING #'S
3519297 = 21cm non
3519410 = 18cm non
3522778 = 18cm non
3521927 = 16cm non
3580651 = 14cm Waste gated
3519297 = 21cm non
3519410 = 18cm non
3522778 = 18cm non
3521927 = 16cm non
Cool thanks
No problem fellas! I've been helped on this site more than not. And the times that I was not, I was able to search this site and find the answer as well as more than I was searching for. Any time I can be of assistance to anyone here I most certainly will. Here's my list of part#'s. Take it as you will some info may and will be incorrect as it has been compiled via searches on this and other sites. I think that my list is probably about 95% accurate, here goes:
0 432 131 715 = 370 horse injectors
0 432 131 753 = 330 horse injectors
0 432 133 854 = 315 horse injectors
0 432 133 864 = 300 horse injectors
0 432 133 879 = 230 horse injectors
0 432 133 844 = 215 horse injectors
NA74X = 215 horse injectors re manufactured
0 432 133 860 = 180 horse injectors
NA71X = 180 horse BOSCH injectors re manufactured
2 418 552 191 = 191 delivery valves
2 417 413 093 000 = over flow valve (old #) *may not need the 000 on the end of the p/n#
2 417 413 101 000 = over flow valve (new #) *may not need the 000 on the end of the p/n#
Injector Washer Dimensions:
O.D.=.589
I.D.=.382
K&N REPLACEMENT CONE ELEMENT RC-4780
**BHAF P/N#'s
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Outerwear cover wr3325-105
**MHAF P/N#
WIX 46637
BIG BORE GM W/CYL'S
RAYBESTOS WC-37337 (L & R)
Boost horn clamp Arvin# 510310 or X310
3901356 - Gasket, Turbocharger Mounting
3937706 - Gasket, Oil Return Line
167050 SCHWITZER BHT3B UNDIVIDED 26 CM HSG
144700-0000 GARRETT BHT3B TURBOCHARGER-NEW
247-4203 ARP HEADSTUDS
CUMMINS APPLICATION HOLSET BHT3B#'S
3522822, 3525299, 3525326, 3525565, 3525573, 3526596, 3526597, 3527046, 3527227, 3527268,
3527547, 3527693, 3527730, 3528201, 3529028, 3529030, 3529031, 3529032, 3529033, 3529034,
3529035, 3529036, 3529039, 3529040, 3529041, 3529487, 3529488, 3532546, 3532823, 3536262
SERVICE KIT THAT FITS ALL OF THE ABOVE BHT3B APPS:
#3545669
Turbo______CFM______Racing HP____Daily HP
HX35______600________420_________330
HX40______800________560_________440
T66_______800________560 _________440
B1________900________630_________495
H2E_______1000_______700_________550
HX50______1000_______700_________550
HX55______1050_______735_________578
HT3B______1100_______770_________605
T76_______1350_______945 _________743
HT60______1400_______980_________770
B2________1500_______1050________825
HX60______1550_______1085________853
T88_____1450-1750__1015-1225____798-963
HT4B______1800_______1260________990
Big Brother_1900_______1330________1045
T91_______2000_______1400________1100
HC5A/HX82_2450_______1715________1348
T100______2600_______1820________1430
T105______2900_______2030________1595
3519297 = 21cm non
3519410 = 18cm non
3522778 = 18cm non
3521927 = 16cm non
3936317 6c lift pump high flow
3936316 6b standard lift pump
marine 370 cpl,#2208, serial# 45432843
headgasket #
stock 3283335
.010 over 3283337
.020 over 3283339
Mind you there is SOME contreversy over some of the Bosch new and old #'s for the 370 injectors but I've done an extensive search on these #'s and have concluded that these #'s are as they say they are. Some injector specialists may disagree and I greatly appreciate their input but these #'s I posted were not posted to create an argument but simply are my conclusion and please correct me as needed! Also note that there is some disagreement on some of the information and it should be used as base line info only (the turbo/cfm chart) 95% of the information I compiled the other 5% is copy and pasted from other websites and such.
O.D.=.589
I.D.=.382
**BHAF P/N#'s
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
**MHAF P/N#
WIX 46637
BIG BORE GM W/CYL'S
#3545669
3519297 = 21cm non
3519410 = 18cm non
3522778 = 18cm non
3521927 = 16cm non
headgasket #
stock 3283335
.010 over 3283337
.020 over 3283339
Mcmopar
18
01-05-2005 07:15 PM
boughtadodge
05-31-2004 09:20 PM
