where to find a 14cm wg housing?
other than the classifieds here, where's a good spot to look for used exhaust housings?
I need a 14cm wg housing for a '94 12V... Thanks. Greg |
Keep an eye on e-bay, I've seen them there a few times
I've done that a few times... main problem for me is they sometimes post actual part numbers, and I have no idea what they mean... if it actually said 14cm housing for a WHC1 or HX35, I could figure that much... Greg |
Originally Posted by BigWaylon
actual part numbers
Greg 3519297 = 21cm non 3519410 = 18cm non 3522778 = 18cm non 3521927 = 16cm non 3580651 = 14cm Waste gated |
TURBINE HOUSING CASTING #'S
3519297 = 21cm non 3519410 = 18cm non 3522778 = 18cm non 3521927 = 16cm non 3580651 = 14cm Waste gated Cool thanks |
Originally Posted by SHARPMACHINE
Cool thanks
ditto...now I have a part number that's valuable!! Greg |
No problem fellas! I've been helped on this site more than not. And the times that I was not, I was able to search this site and find the answer as well as more than I was searching for. Any time I can be of assistance to anyone here I most certainly will. Here's my list of part#'s. Take it as you will some info may and will be incorrect as it has been compiled via searches on this and other sites. I think that my list is probably about 95% accurate, here goes:
0 432 131 715 = 370 horse injectors 0 432 131 753 = 330 horse injectors 0 432 133 854 = 315 horse injectors 0 432 133 864 = 300 horse injectors 0 432 133 879 = 230 horse injectors 0 432 133 844 = 215 horse injectors NA74X = 215 horse injectors re manufactured 0 432 133 860 = 180 horse injectors NA71X = 180 horse BOSCH injectors re manufactured ---------------------------------------------------- 2 418 552 191 = 191 delivery valves 2 417 413 093 000 = over flow valve (old #) *may not need the 000 on the end of the p/n# 2 417 413 101 000 = over flow valve (new #) *may not need the 000 on the end of the p/n# Injector Washer Dimensions: O.D.=.589 I.D.=.382 ---------------------------------------------------- K&N REPLACEMENT CONE ELEMENT RC-4780 ---------------------------------------------------- **BHAF P/N#'s Fleetguard AH19037 NAPA 2790 WIX 42790 Donaldson B105006 Baldwin PA2820 Hastings AF1012 AFE 20-40044 Carquest 87790 John Deere pmah19037 Big A 93790 Caterpillar 3i0005 Fleetrite ahr819037 Luber-finer laf2531 Fram ca6818 UNI 908 Outerwear cover wr3325-105 **MHAF P/N# WIX 46637 ----------------------------------------------------- BIG BORE GM W/CYL'S RAYBESTOS WC-37337 (L & R) Boost horn clamp Arvin# 510310 or X310 ----------------------------------------------------- 3901356 - Gasket, Turbocharger Mounting 3937706 - Gasket, Oil Return Line ----------------------------------------------------- 167050 SCHWITZER BHT3B UNDIVIDED 26 CM HSG ----------------------------------------------------- 144700-0000 GARRETT BHT3B TURBOCHARGER-NEW ----------------------------------------------------- 247-4203 ARP HEADSTUDS ----------------------------------------------------- CUMMINS APPLICATION HOLSET BHT3B#'S 3522822, 3525299, 3525326, 3525565, 3525573, 3526596, 3526597, 3527046, 3527227, 3527268, 3527547, 3527693, 3527730, 3528201, 3529028, 3529030, 3529031, 3529032, 3529033, 3529034, 3529035, 3529036, 3529039, 3529040, 3529041, 3529487, 3529488, 3532546, 3532823, 3536262 SERVICE KIT THAT FITS ALL OF THE ABOVE BHT3B APPS: #3545669 ----------------------------------------------------- Turbo______CFM______Racing HP____Daily HP HX35______600________420_________330 HX40______800________560_________440 T66_______800________560 _________440 B1________900________630_________495 H2E_______1000_______700_________550 HX50______1000_______700_________550 HX55______1050_______735_________578 HT3B______1100_______770_________605 T76_______1350_______945 _________743 HT60______1400_______980_________770 B2________1500_______1050________825 HX60______1550_______1085________853 T88_____1450-1750__1015-1225____798-963 HT4B______1800_______1260________990 Big Brother_1900_______1330________1045 T91_______2000_______1400________1100 HC5A/HX82_2450_______1715________1348 T100______2600_______1820________1430 T105______2900_______2030________1595 ----------------------------------------------------- TURBINE HOUSING CASTING #'S 3519297 = 21cm non 3519410 = 18cm non 3522778 = 18cm non 3521927 = 16cm non 3580651 = 14cm Waste gated ----------------------------------------------------- 3936317 6c lift pump high flow 3936316 6b standard lift pump ----------------------------------------------------- marine 370 cpl,#2208, serial# 45432843 headgasket # stock 3283335 .010 over 3283337 .020 over 3283339 ----------------------------------------------------- Mind you there is SOME contreversy over some of the Bosch new and old #'s for the 370 injectors but I've done an extensive search on these #'s and have concluded that these #'s are as they say they are. Some injector specialists may disagree and I greatly appreciate their input but these #'s I posted were not posted to create an argument but simply are my conclusion and please correct me as needed! Also note that there is some disagreement on some of the information and it should be used as base line info only (the turbo/cfm chart) 95% of the information I compiled the other 5% is copy and pasted from other websites and such. |
Wow!!!!!!
is that a post or what? thanks again |
Very Nice THANK YOU
