Drag comp vs. Adrenaline vs. Redline box...same dyno, same truck, same day!
Old Nov 1, 2009 | 12:08 PM
  #46
Dinner's Avatar
Wow def didn't guess right, haha. Nice to see the numbers you got for us!
Old Nov 1, 2009 | 02:56 PM
  #47
RowJ's Avatar
FWIW - The new (Sept, 2009) ADR3000 tune and the new Comp tune sure don't feel the same on the Hwy. And if you check the setting under 'custom tuning', they sure aren't close. Hard to believe they show the same on the dyno... unless the test truck was over fueled on all runs?
Also, put about 400 miles on yesterday...all hwy, and all w/o Smarty and with ADR on 3000 tune.... PL05.
In addition to cruise control being a dream w/o Smarty, I noticed much less smoke and more than enough acceleration when needed.
Filled up this AM and got 1 mpg better than I average with Smarty/Adrenaline stack!!
RJ
Old Nov 1, 2009 | 04:46 PM
  #48
01 Diesel Nut's Avatar
Originally Posted by Crazydave
What you put in as a base tune (the one in the box) I think has a lot to do with how the two saved tunes behave. For example when i got the 70% tune from you my, fuel sender read correctly on all tunes. ( had the old sender from the beta testing days and the newer software didn't support it) and the wire tap issue happened on all tunes when that was in as the base.
One more thing to note, is the torq tune will only give you 2400us of pump stretch if its the base tune. If you manually tune, the pump stretch stops at 2200. If you load it, and save it to T1 or T2 it will automatically drop down to 2200, but if its loaded as a default you will have 2400 for pump stretch.
So you should save the torque tune as the factory tune to get the 2400 pump stretch?
Old Nov 1, 2009 | 06:39 PM
  #49
Crazydave's Avatar
Yea. If you save it as T1 or T2 it drops down to 2200, custom tuning will only let you turn it as high as 2200. But if you load it and look at tuning parameters it will say 2400us.
Old Nov 1, 2009 | 08:34 PM
  #50
Hmm, might have to see about downloading it, haha.
Old Nov 1, 2009 | 08:37 PM
  #51
J Lent's Avatar
Thanks. I know there is more left in the Adrenaline, but I only had one shot at it.
Old Nov 1, 2009 | 11:04 PM
  #52
Dinner's Avatar
Yeah that's kinda crummy. Are you going to try and squeeze some more out of it, or wait a bit and just run it as is?
Old Nov 1, 2009 | 11:17 PM
  #53
J Lent's Avatar
I usually only dyno once a year for fun. There is now a dyno very close to home so, we will probably try again next spring.
Old Nov 2, 2009 | 07:28 PM
  #54
WVU Dodge's Avatar
I just checked out that shop's website. Looks like a nice place. I may have to check it out sometime. Prices are a little steep compared to the last 2 times I've been on a mobile dyno, but I've seen them higher.
Did it have any trouble loading up your truck. Were you seeing full boost compared to the street or sled? And did you use high gear?
Congratulations on the good numbers.
Old Nov 2, 2009 | 08:46 PM
  #55
J Lent's Avatar
Yeah, I ran 12 times trying different things to get loaded. In the end, we had to ride my foot breaks to get it spooled to full boost. I hit 57psi & I see 62 on the street. I ran in 5th gear [nv4500]. I just turned the ADR on PL10 & dynoed, with some tuning, I know I can get another 30hp out of it easy.
Old Nov 3, 2009 | 05:39 AM
  #56
Brian Lent's Avatar
30? You only needed 3! haaah
Old Nov 3, 2009 | 07:08 AM
  #57
stevewes2004's Avatar
good numbers man, and you have a stock SOvp?
Old Nov 3, 2009 | 03:35 PM
  #58
Big Blue24's Avatar
Yes, JLent has a stock SOvp.
Old Nov 3, 2009 | 07:45 PM
  #59
J Lent's Avatar
Yep, Reman SO vp44 from II, thanks BB24
Old Nov 3, 2009 | 08:57 PM
  #60
Mike Holmen's Avatar
The Guru
what your egt's like during the pull? Nice numbers. Try a set of twins and see how much your power/torque goes up by.
