#1 |
The Admin that's here for you!
How to: Block heater cord install
Evenin, DTR...
Since I did it tonight, I took some pics. As far as I know, the block heater is standard, but the plug is not. I got my plug from a Cummins shop, but you can get them from geno's too. It's a lot cheaper than the Dodge parts dept... Remember, safety... watch the battery terminals, and if you take the intake off, watch the turbo fins and make sure nothing is left over to get sucked into the turbo... First: Remove the intake. ![]() Behind the oil filter and under the manifold is a plastic cap. ![]() ![]() Take it off. ![]() ![]() Inspect the plug to make sure that the ground strap is not bent up, and that there is no debris in the plug. ![]()
__________________
Mark 04.5 3500 SRW 4X4 Smarty REVO PoD, MP8, HTT 64/71/16ss, Flux 2.5, ARP studs, ATS stage 4 with aftermarket output, Snow stage 3 water/meth, AD 150, Arson II CP3 mod. 37" BFG KM2 MT's on stock rims and ride height. 636/1266 fuel 868/1778 on a little spray David Dunbar's dyno, 7 Nov ![]() 12.46 @109 Coastal Plains, Oct 08 Many thanks to Lary Ellis and the DTR store, ATS, Don M, and Bob W... madhat@dieseltruckresource.com |
#2 |
Install the plug. Make sure that it seats tightly. I would reccomend some anti-seize on the threads.
![]() Tighten the nut. ![]() Then, drop the cord down and route it to the bumper. I tie mine up with zip ties. Watch for sharp edges, and make sure to keep it off the rad. ![]() ![]() And I zip tie mine to the tow hook. ![]() I would also reccomend putting some anti-seize on the plastic cap when/if you reinstall it next year... HTH... mad |
#3 |
And BTW, How do I get the "Registered User" under my name changed?
Luckily mine came with one but thanks for the good clear pics madhat!!
Those will be a great help to those who want to do this.
__________________
Tow vehicle...2006 Atlantic blue Mega Cab 2500 4x4 6 spd. 3.73's CTD 325/610.. Silencer Ring gone...Amsoil EAA189 filter... Air Box mod... Quadzilla Max Mileage Module... Fuel Tank Vent Mod... Muffler gone Member #3 of DTR Megacab Club Join Here Member #12 of DTR GoofBall Club Join Here Towed.. Jeep CJ7, 304 with Holley Fi, T-18 trans, Dana 300 with 4 to 1 gear set, Dana 44 with Detroits F&R, 35x16.5x15 Boggers with MRT bead Locks, and way too much more to list. |
#4 |
That's what we're here for!
#5 |
Thanks for taking the extra time to do this. I have been curious about this for a while just never needed it bad enough to do it.
Are you supposed to remove the cord in the summer or is it a permanent install? TIA
__________________
White 04 2500 4X4, QC, SB, 48RE, 3.73 gears JTT built DTT BFG 315's, SuperLift Leveling Springs w/ Rancho RS9000X's, Frontier Replacement Bumpers Smarty Jr. and Dr Performance Predator, Flux 1.5's, Commander w/FP kit, GDP Walbro pump Airaid filter, Aero Turbine muffler, 5" MBRP Tip |
#6 |
Permanent install. Pics in my gallery of what I did to relocate it. I don't have that cord hanging around now.
Nice write-up
__________________
CWO4 US Marine Corps 04 3500 SRW 4X4 305/555 Goerend 48RE w/Billet input, Billet Flex plate, Triple disk, 4.10 Offroad package, Rhino Spray-in liner, Access roll-up cover, Step Bars, Billet Grille, Monster exhaust w/Aero 4040, Ultra-lite gauges, Smarty, MP-8, Glacier fuel system, Bilstein 5100's, Firestone air bags, 2 micron filtering, S&B intake, GDP intake horn, HE351. SAC #260 73 Duster street driven 493 ci, 6.0's in the 1/8th 9.62 1/4 so far. |
#7 |
You can remove it in the summer, I do, but you don't have to.
Thanks, Sir! |
#8 |
Is that a mopar plug?
The one I got had a different end on it, and has the little plastic clips that go in existing holes in the frame to route the cord. I leave mine in year round, but I just tuck the cord behind the bumper during the summer, then move it underneath where the foglights are during the winter...
__________________
'07 2500 Mega 2wd/G56 |
#9 |
Got it from the cummins dealer in North Charleston.
#10 |
Thanks for the write up with pics. It'll help newbies like me.
__________________
06 3500 SRW Mega-Laramie 4" lift & 35"MT/ATZ's, Cat MIA,AFE Drop-In, AMP Research Steps,Roll-N-Lock tonneau,Smarty Jr.,Quad Boost Fooler, Homemade Cat 2 micron setup PSC Steering brace, Billet TC and some tranny work, 4.10's Don't worry about the Mule, Just load the wagon! DTR Megacab Club Member #229 2008 32' Silverback, Super-Glide Hitch, 36gal aux. tank, Airlift Wireless airbags |
#11 |
Block heaters are great!!!!!
I love my block heater. I use it all the time. If I do not use mine it takes 20 miles for the heater to blown hot air. If I plug it in within 2 miles I get hot air. The best $20.00 Bucks I ever spent. I want to get the cold front but I don't think I need it here in Virginia. Any opinions?
__________________
2006 Flame Red 2500 4X4 Bone Stock 48RE SIRIUS SAT. |
#12 |
my question , what kind of camera do you have,and what were the settings? those pics are really clear
__________________
01 3500 ho 2WD;4 inch exhaust bully dog stage 3 inj edge comp(removed hybrid hx 35/40 8/25/04) dyno 419.2 hp 891.8.torque w/stage 2`s on a dyno jet 6/25/03 ,htb2 turbo installed 8/25/04, not a dually any more,conversion done in 04... added home designed propane march 07 (to improve mileage) new vp 44 from industrial injection 3/july/07 181000 miles, removed stage 3 injectors ,reinstalled stage 2 to try to control EGT's better |
#13 |
It's a Sony cybershot DSC-W80, and I had the resoultion turned all the way up... 7.2 mega pixels, then I load them on photobucket so I can use the full size pics here.
It's a great camera, and I love it. I got it for 189.99... http://www.dcresource.com/reviews/sony/dsc_w80-review/ I can get them pretty cheap at the exchange. |
#14 |
I just ordered a fleetguard cord from genos for 11.95 plus shipping ,man i wish i would have ordered one two years ago.
__________________
Red 05 QC SB, 6spd, FASS 150, Beta 4.3, mp-8, SB 3600, F1 Stix, Floor It Pump, Twins. 642 HP @ Mid-Atlantic Diesel Dyno Thanks Lloyd Mid-Atlantic Diesel Performance |
#15 |
I bet, in Pee-A...
| Thread Tools | |
| Display Modes | |
