Attempting to save a dodge...
Old Mopar Aficionado Extraordinaire
Yes... But it's gets too messy, and I don't have a power respirator ...yet
Good catch. it is rustoleum. I used it on my toyota last year, and it wears like iron if prepped properly.
I'm in Central NJ on the coast.
NJT ? I'm from NJ, and my nickname is " T. " I'm actually a Rutgers Alumni...
When is there going to be a NJ MEET ? Say @ the water gap ? or at Hot Dog Jonnies on rt 46 ? Hopefully I'll be done by then ...
Invest in a power washer. Minimum PSI of 3K. You won't be disappointed as I've found more uses than I can ever imagine I ever would have.
Got the washing my truck time down to around 15 minutes !
I don't know about the meeting in the gap or Johnnies. I don't keep track of that stuff.
Keep up the good work. I'll be watching
Received 1,637 Likes
Waiting on parts to finish it.
Rear drivers side frame
Rear passenger side frame
Need to do some touchups before calling it finished ..... for this year.
Looking good.
You said you used a "pump sprayer" for the rust-converter stuff.
Did you mean like a Windex bottle, or did you mean like a 3-gallon garden-sprayer ??
How did you buy the stuff, in quart bottles or in much larger quantity ??
How much did the job take ??
Thanks.
Thanks.
BK
I bought 1 gallon sprayer, as it's small enough to maneuver around. Don't overpump it, as the lower the pressure, the better. The stuff burns, and a strong gust will make you wish you hadn't. You will need to cover yourself completely, with splash goggles. It WILL BLIND YOU if exposure is great.
I bought them in one gallon containers. My local sherwin williams dealer sells them, but most don't stock the product, as per my request, they now do.
I'm at about a gallon and a half, but I did everything that has rust on it... bumpers, driveshaft, frame, inner cab mounts (no rust... just preventative), rocker wells (inside), Etc. You're really not required to topcoat in unexposed areas, so it's perfect for inside body panels. It continues to protect, long after application.
You should pay about $25 a bottle... although I get a contractor's discount @ my SW dealer.
I put the solution inside my bumper (Bumper on ground upside down) as I removed my bumpers to gain maximum access., and let it sit overnight. Where it pooled, the rust was completely gone, and fresh metal left behind. Really amazing stuff. Where it didn't pool, I had to reapply the next day. The key to using the stuff is letting it sit overnight, not exposing it to water
Good luck, and let me know how it works for you.
T.
T.
I have a suggestion for guys looking to save their trucks.
At the front of the rocker panels are oval sheetmetal covers. Unscrew them and remove them for access to the inside. Use compressed air and blow out the rockers. They get leaves/ sediment in them over the years.
It may sound crazy, but all the water that gets into the cowl area drains into the rockers, then out of drain holes in the lower rocker spotwelded area. If those holes get plugged, water just sits in there and the moisture eats the sheetmetal away. I cleaned and dried mine then painted inside them with a rust preventative coating similar to por15. If you want to coat them as I did it gets involved, but just blowing them out and cleaned would go a long way to saving the truck.
Cool,
I could use another dodge to beat on while it's here..... Since my lower back and neck strain, from crawling around (upside down) for the last two weeks, has really made me feel goooooood..
I've gone through more laundry detergent than one man should be able to . The wife is P.O'd
I pulled the rubber / plastic plugs out and washed out as much as I could of all what was in there. Didn't see a oval plug that was "screwed in".
Where abouts ??
The third gen doesn't seem to have the problem
The plugs are on the firewall side of the rockers. The only way to access them is to remove the inner fenderwells. This is not as difficult as it may seem. The fenderwells come out through the bottom/ wheelwell. Removing them will also give you great access to clean out the lower fenders. I dont have any pictures of these plugs. Maybe someone has a picture of a bare cab firewall to give you an idea of what I'm talking about. The holes are about 2"x3" and allow a full view of the inner rocker. Alot of work, but well worth it in my opinion.
Here's the truck with a new front suspension setup in it. I ordered new springs and had them add leaf glides in between each leaf, and two inches in increased height. The entire frame has been derusted, primed and coated. Today I removed the fuel tank and it was full of leaves behind there. Cleaned it all out, and applied the rust converter to it. Pictures came out blurry, so I won't post them.
Installed a new fuel sending unit and installed new u-joints in the rear driveshaft, including a new carrier bearing. The carrier was bad, so it was time for replacement, including the new joints.
Prime and paint behind the fuel tank tomorrow, and after a few days of drying, I'll put it all back together.
Can't tell you how much better this truck rides and handled, especially since I replaced those frame bushings. Truly amazed at the difference from the original springs. Night and day!
Again, Thank you Jim Lane for the thread about improving your ride. You were dead on, and those glides made a world of difference in how the truck rides. Great advice, well taken and appreciated.
T.
T.
Instead of spending all the hours like you did on yours, I am just going to spreay used motor oil under mine and do that every year......although I wish I could do what you have already done.
Rug_Trucker (11-05-2022)
Cummins anti-corrosion system in full effect!
