Zeroing the Steering Wheel without a sector shaft connected
I'm trying to center the wheel before I put the SSS On the truck. I don't think you can go in the cab and spin the wheel like on the Price is Right and just throw the shaft on wherever the wheel stops at. For some reason the airbag, radio wiring, cruize control, clockspring do funny things when you do that.
Steering sector shaft is not on the truck, so adjusting that will do nothing for the steering wheel.
I have never had my Dodge off at the input to the steering box, so I can't say the splines aren't one position only like others. I am going to set this one out for now.
That's the way it's normally done.
Wheels pointed straight ahead with the clockspring half unwound or in the shipping position.
Steering boxes vary quite a bit in the number of turns from bump to bump depending on the brand and type, don't think you can use box turns as a guide with the clockspring
the factory designed the system to go lock to lock without damag to the clock spring, or any other wirein`.the OP did not take the wheel off the input shaft, so there`s no chance of screwin` it up.
He didn't take the wheel off, but the intermediate shaft (he called it the sector shaft) is not on the truck.....no connection to the box, so the wheel will not stop at the lock. It will continue to spin and break the clockspring.
Anytime I change a steering box I just connect the sector shaft last. Install drag link/pitman arm to box, then jack front end up and manually pull the wheels so they're close to straight (assuming the shaft came out with the wheels straight) and line the two up. I guess this only works if your 4 year old doesn't hop in and start steering the boat in between.
I don't know how to find "center" on a clockspring. When removed, they don't like to turn freely. Pretty sure the center needs pressure on it to spin.
But, if you can figure out where the clockspring "at center" is. (it may even be "at rest" when centered?)
Steering wheel has a mark on it that should be lined up with a mark on the column. Clockspring should be centered to allow the steering wheel to be installed with these two Marks lined up.
Once steering wheel is installed, Lock it in place with the ignition/key off.
Connect intermediate shaft with the front wheels as close to straight as possible.
If steering wheel is not straight when driving straight, you'de need to have an alignment shop asjust the tie rods as needed to center the steering wheel.
I've always removed the clocksprings with the wheel centered so as not to mess up a clockspring. If your clockspring has been messed with or turned too far already, or you just don't know if it's centered? I don't know how to get it back correct.
I read the whole question, and there`s no way turning the steerin` wheel all the way to the stops will hurt the wirein`, so,what`s the problem ??
the factory designed the system to go lock to lock without damag to the clock spring, or any other wirein`.the OP did not take the wheel off the input shaft, so there`s no chance of screwin` it up.If he has the clockspring, he can damage it by over turning it, so he is trying to center the wheel to provide the clockspring its correct range.
Anyhow, sounds like he is getting some good answers now.
