Would my exhaust setup be bad?
Old Mar 24, 2008 | 10:12 PM
sallyman1's Avatar
I just got my autometer dash pod today. Gauges are on the way and a rail gauge.
Anyways what i did to my exhaust was this: Since I have a 2004.5 i left the factory 4 " exhaust. I used a sawzall and cut my catylic converter out. I then stuck the aero4040xl there the way it goes with arrow towards back of truck. I drilled a few holes on each side and fastened aero with pop rivets and then I stepclamped (bandclamp)over top of the rivets. I then sawzalled stock muffler off and put a muffler delete pipe from genos garage where muffler was. I did the same by pop rivetting ends and then stepclamping overtop. I used high temp silicone under stepclamps as well.
Could my exhaust be my egt problem because its factory 4" and not mandrel bent?
Old Mar 24, 2008 | 10:29 PM
06RAM2500's Avatar
What are the egt's running?
Old Mar 24, 2008 | 10:42 PM
sallyman1's Avatar
as you all know 700ish F on highway 65 mph empty. When i mash on pedal it jumps to 1450 F FAST and edge juice attitude alarm goes off and defuels. I have the defuel set for 1250 F and the alarm for 1450 F. Funny thing is even though backdown is 100% it still gets to 1450. And thats on level 1 to. Level 0 Stock is the same. I will unhook edge when ALL my gauges come but I was thinking other day of my exhaust being the problem maybe.
But shouldnt my surrent exhaust setup be better than factory?
Old Mar 24, 2008 | 11:54 PM
Fisherguy's Avatar
Mine never gets above 1250º with the truck fully loaded and towing the trailer up hills in 6th gear.
What kinda gauge you have? I wouldn't trust it, no way it should be getting that hot so easily.
Old Mar 25, 2008 | 06:32 AM
AlCorr's Avatar
Your exhaust sould NOT be a problem with that set-up. (you sure the arrow points to the rear of truck)????????
Old Mar 25, 2008 | 06:39 AM
sallyman1's Avatar
yes. another way to tell is that the A on aero is towards the back bumper and the O on aero is towards the front bumper. right? plus the arrow is right.
Old Mar 25, 2008 | 06:40 AM
sallyman1's Avatar
can someone check their AERO writing to clarify this please?
Old Mar 25, 2008 | 08:20 AM
jrussell's Avatar
Your gauge is the one I wouldn't trust! A stock '06 should be able to max out at 1300-1400* pretty easy.
Now if you're talking 1250* just cruising up hills when loaded then that would make sense. He was talking max EGT's so of course those will be higher than towing EGT's.
You're chasing a ghost man. Those EGT's are perfectly normal for your truck. If anything is wrong it's likely the Edge EGT gauge. Those have been known to have problems. Definitely not your exhaust. The stock 4" is good for 600+hp.
Old Mar 25, 2008 | 08:38 AM
Fisherguy's Avatar
Okay, sure, so you're saying a bone stock truck will hit 1400* from the factory? Isn't that well into the red on your pyro gauge, to the point you're doing damage to the engine? I don't think that's right.
Old Mar 25, 2008 | 08:57 AM
jrussell's Avatar
Yes, most of the later trucks run that hot straight from the factory. Ask around and you'll see. Apparently it doesn't do damage.
Old Mar 25, 2008 | 09:00 AM
Fisherguy's Avatar
Okay, you got me wondering, so I asked:
https://www.dieseltruckresource.com/...d.php?t=198242
Old Mar 25, 2008 | 09:25 AM
2003Ram's Avatar
My guess is the "Edge" is your problem and not the exhaust.
ryanihf250
Jan 17, 2008 02:58 PM
trik396
Jul 11, 2006 12:08 AM
Moking 24V
Dec 15, 2004 06:28 PM
LanceD
May 11, 2004 07:55 PM
RHC
Aug 1, 2003 07:30 PM
