would an HT80 work in a twin setup?
Old May 11, 2004 | 10:48 AM
LanceD's Avatar
I found me a cheap HT80 and could I use it with my HX35 in a twin setup, or has anyone used one of these before?
thanks!
Old May 11, 2004 | 11:53 AM
Idaho CTD's Avatar
A HT80 is a huge turbo and would be unpractical for a daily driver. The only reason I could see a use for one would be a sled pulling only truck.
Old May 11, 2004 | 01:17 PM
GO 4LO's Avatar
Really? Even for the primary in a twin setup? I'd have guessed the '80 to be about the size of an HT3B. No?
Chris
Old May 11, 2004 | 01:36 PM
Idaho CTD's Avatar
A HT60 is generally a little larger than a HT3B. A HT80 is on even a larger frame than the 60's. If you look on Holsets website you'll get a idea of how much larger the 80 series turbos are then the 60's.
For example: 60 specs are 18-22kg in weight and airflow of .95kg/sec
80 specs are 32-50kg in weight and airflow of 1.5kg/sec
Old May 11, 2004 | 01:39 PM
GO 4LO's Avatar
Holy cow!! Thanks for the info - I'll check out that site.
Chris
Old May 11, 2004 | 07:55 PM
LanceD's Avatar
Length mm 332
Width mm 318
Height mm 300
Smallest Mass kg 32
Largest Mass kg 50
Airflow kg/s 1.5
I guess thats the size of it, what is that compared to say an HT3B?
1974d2004x4
13
Oct 17, 2007 07:47 AM
BigBlackBeast05
Jul 24, 2005 09:47 PM
MoreSmoke
15
Jan 8, 2004 12:24 PM
GO 4LO
Jan 1, 2003 10:33 AM
