Wiring pyro
Old Aug 5, 2006 | 02:02 PM
dover's Avatar
Wiring pyro
After reading that the pyro hot lead should be wired into a keyed hot while cranking circuit I was wondering if anyone could save me some work and tell me where they tapped in at?
Thank You,
Ben
Old Aug 5, 2006 | 07:23 PM
dslpower's Avatar
Pyro Wiring
When I installed my gauges, I ran the red wire to behind the fuse panel and spliced it into the wire that powers the turn signal can. If I remember right it is a brown wire.
Pull the flasher can and use a test light or volt meter to see which one has 12v with the key on.It does not have to have 12v to the gauge while cranking, only running.
I hooked the gauge lights up to the headlight switch so they dim with the dash lights.
Old Aug 6, 2006 | 09:58 AM
dover's Avatar
That was my plan and the way I did it on the Ford(keyed hot). Silly me for actualy reading part of directions
Ben
53 willys
Sep 7, 2010 10:52 PM
powersmoke
Apr 19, 2009 07:29 PM
Evildiesel
Jul 2, 2006 06:39 PM
apache
Nov 4, 2005 09:54 PM
charcoal600
Apr 30, 2005 02:34 PM
