What wires to make it run
Old 11-26-2011, 08:38 PM
Justin Rhodes's Avatar
On my 94 parts truck, it has the wiring cut coming off the battery. Im needing to know what is the bare minimum wiring to make it run. Not talking about starter, i have a jumper cable from the battery straight to the starter and theres a negative battery cable they left. I was thinking the shut off solenoid was the only thing i needed to rewire up and it would run. Any thoughts? Thanks
Also is the 1125cca battery out of the first gen enough to start it?
Old 11-26-2011, 09:03 PM
bob95065's Avatar
The fuel shutoff solenoid should be in the up position to run. That and the starter are all you need.
Old 11-26-2011, 09:13 PM
Alright, I've never actually messed with a ppump before so this may be a stupid question. There isnt any kind of lever to pull the shut off solenoids plunger up is there? i know on a first gen there isnt but i just wanted to check. Less wires to run the better
Old 11-28-2011, 07:46 AM
patdaly's Avatar
Easiest to just put a cable on the lever ( remove the solenoid ).
Voila, no wires needed!
Old 11-28-2011, 08:14 AM
I'm using this engine to ppump my first gen which already has a pull cable on it.
mtdoragary
08-12-2013 10:31 AM
95black2615
16
10-08-2008 08:37 PM
feveree40
10-03-2007 03:59 PM
andyr354
12-18-2004 05:56 PM
Bean
08-10-2004 08:24 AM
Quick Reply: What wires to make it run
