Width of dually
Old Aug 14, 2008 | 04:17 PM
921stgen's Avatar
Width of dually
Can someone give me the total distance between the outside to outside of the inside dually tire and the distance between the outside to outside of the front dually axle either on a regular truck w/ a bed or a cab and chassis model. thanks
Old Aug 14, 2008 | 05:12 PM
powerrammaster's Avatar
Not sure if your aware but the distance(width) of a cab and chassis dually is 5" narrower than than that of a truck from the the factory with a pickup box. Sorry I can't help with the measurements, none here presently.
Old Aug 16, 2008 | 07:35 AM
BTM's Avatar
BTM
Just under 96" I had to cut the trim on the garage door opening to fit my truck inside. Rich
Old Aug 16, 2008 | 11:14 AM
bjytech's Avatar
The length from the outside to outside of the inner tire is about 68 in. and from the outside to outside of the outer tires its about 88 in. on my dads 91 cab and chassis model
Old Aug 16, 2008 | 11:24 AM
Colo_River_Ram's Avatar
With age comes the cage
go to dodge dot com and down load the up fitters guide for your truck..it has all dimensions you need..
Old Aug 18, 2008 | 10:34 PM
921stgen's Avatar
Thanks, guys for the info.
vegasbound
24
Feb 10, 2009 03:51 PM
Mud Ready
Nov 18, 2007 09:04 AM
jj3500
May 13, 2006 08:44 PM
Patrick Campbell
Jan 18, 2006 08:23 AM
rkelso98
Feb 28, 2003 02:37 PM
