Who's swapped Auto to Getrag?
Old 07-05-2007, 07:47 AM
rbrettctd's Avatar
How did you correct the speedometer? Does it correct it to put the speedo drive from my 727 in my Getrag?
Old 07-05-2007, 10:09 AM
BHD
BHD's Avatar
I had to use the speedo transmission adapter from my donor truck. Mine was 4wd, not sure if the speedo trans adapter is the same as two wheel.
Old 07-05-2007, 10:44 AM
rbrettctd's Avatar
Ive got the adaptor that was on the transmission, which one are you talking about?
Old 07-05-2007, 02:42 PM
RumbleFish's Avatar
you need a reduction box. dpuckett knows a good place to get one, as the one from the dealer is like $80.
Old 07-05-2007, 06:03 PM
rbrettctd's Avatar
There is a box on my Getrag for the speedo, with a gear in it. I assume this is a reducer box? My question is how to make the speedo right, to use my 727 speed pickup or just this box, maybe regeared if needed.
Old 07-06-2007, 06:01 PM
Just thread your VSS onto the reducer box on the Getrag. Speedo will be off due to the 3.07 gears, though.
Old 07-06-2007, 06:05 PM
rbrettctd's Avatar
Tahts the answer I was hunting. Can I get a different speedo gear to make it right?
Old 07-06-2007, 06:09 PM
Hang on a couple minutes while I look in the book...
Old 07-06-2007, 06:17 PM
My parts manual doesn't list the Getrag/3.07 combo, but a good Dodge parts guy can set you up with what you need. The parts exist because you could special order 3.07's with the Getrag.
rbrettctd's Avatar
Alright, and Dave what do you think about drilling and tapping a hole in the top plate close to the shifter for a fill hole?
Old 07-06-2007, 06:18 PM
rbrettctd's Avatar
I bet I could take it to a speedo shop and have it done right...if I can find one.
Old 07-06-2007, 06:25 PM
I think it's easier to put an elbow in the fill hole...
Old 07-06-2007, 08:05 PM
BHD
BHD's Avatar
I don't know if the reducer gear box is the same on two wheel drive. When I swapped the transfer cases I had to use the reduction gear box from my old transfer case behind the 727. Speedo is right on now. Sorry I can't help more I don't know much about the 2wd stuff.
Old 07-06-2007, 08:44 PM
rbrettctd's Avatar
Well my 727 is direct I believe, with no reduction box.
Big Deezul
05-14-2009 07:25 PM
030303
09-19-2004 12:17 PM
Jambbii
08-03-2004 02:49 AM
converteddzlr
02-10-2003 12:14 PM
Quick Reply: Who's swapped Auto to Getrag?
