which mod first?
Old Feb 19, 2008 | 02:00 PM
jmd025's Avatar
which mod first?
Looking for advice from somebody who has done this:
I want about 50-60 more hp and 150-200 more ft/lbs in my 24v, along with a 2 or so mpg improvement.
Looking at RV275's or a Quadzilla XZT+. Which would you do first? If you have done it, what gains did you get? This is a tow rig 1st, play rig 2nd!
I will have boost and pyro before either. I have the BD low fuel pressure warning already.
Need some opinions because the tax refund is on the way, and I'm getting antsy!
Thanks guys,
Josh
Old Feb 19, 2008 | 02:17 PM
J Double's Avatar
I know there's a Smarty in the classifieds. The Smarty really shines for the towing crowd. I just don't tow with the truck anymore.
Old Feb 19, 2008 | 02:23 PM
jmd025's Avatar
I agree, I have heard good things about the Smarty, but i am looking for "on the fly" power setting changes. Smarty doesn't do that right?
I think I am leaning more heavily toward the injectors first, box/programmer later.
Keep the advice coming!
Josh
Old Feb 19, 2008 | 03:24 PM
displacedtexan's Avatar
You will need the boost fooling of a box to get all the benifits of injectors.
I'd look at a VanAaken and a set of smallish sticks. (The VA has more low end than the Edge EZ)
But either one of those two boxes (with or without sticks) is the most popular towing combo
Old Feb 19, 2008 | 03:27 PM
haloman's Avatar
Do the XZT and 275's if you can, that will be a great towing combo.
Old Feb 19, 2008 | 03:37 PM
bullboy85's Avatar
i just have an XZT+ and it does great for towing with stock sticks, id go box first and sticks later, after feeling what the box will do you might want to go even bigger in the sticks, i want some mack 1.6's now insted of the 275's but i have to look at my trany first.
Old Feb 19, 2008 | 03:46 PM
jmd025's Avatar
thanks guys!
I'm pretty sold on the XZT+ and the 275s, I am really just wondering which will be the best order to get them in. It may be a while between purchases.
So which is it, the 275s or the box first?
Josh
Old Feb 19, 2008 | 03:54 PM
bullboy85's Avatar
well ur probibly going to get alot of mixed thoughts there, my thoughts are and were when i made my choice that youd need the boost fooling of the box to get the full binafit from the 275's, sence there smaller im not positive thats true. i have heard before that you feel a bigger difference adding the injectors after the box then you do before.
Old Feb 19, 2008 | 07:29 PM
heykw's Avatar
I would buy a trans first
Old Feb 20, 2008 | 07:37 AM
jmd025's Avatar
sorry, I dont drive automatics. Maybe you meant clutch??
Old Feb 20, 2008 | 07:40 AM
Hintz's Avatar
personally, Id do mach 1's over the 275s for a little more cash you get a much better injector
Old Feb 20, 2008 | 07:42 AM
jazz_kt's Avatar
What you want now and what you will end up with are 2 totally different things. Take my advice and buy once. Adrenaline!!!! nuff said
Bradleysram
19
May 12, 2009 08:36 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
Apr 23, 2007 06:46 PM
One Way
21
Oct 18, 2006 05:21 PM
RAMV
Jul 14, 2004 12:08 PM
