What's a 727 worth?
Old Dec 1, 2006 | 12:05 PM
PeytonMaterne's Avatar
What's a 727 worth?
Any guesstimates? Looking at one with "112,000" on it. Stock converter, with flexplate, starter, and block adapter.
Old Dec 1, 2006 | 02:06 PM
sdstriper's Avatar
How bad do you want it? If I were looking for an automatic for a Cummins I would strongly suggest a 4 spd OD unit. The stock OEM or equivalent converter is weak at best and the flexplate of any 1st gen CTD should be upgraded to the 94' and up flexplate or SFI unit. My two cents, take it for what it's worth...
Old Dec 1, 2006 | 04:43 PM
EClancy's Avatar
i dont think they are worth all too much for this kind of application, there are better choices, as already stated. Id i had to have one, i'd think $200 max
Old Dec 1, 2006 | 07:45 PM
That's kind of what I was thinking, If I need to upgrade the flexplate and converter I don't want to put a whole lot into a "core". I want to build a truck like jugheads so a 727 is all I need.
Old Dec 2, 2006 | 12:03 AM
sdstriper's Avatar
You can get a flexplate new from Cummins for just over $100. A better than stock converter between $360-500.00. Not too long ago I bought a master kit with Red Eagle clutch's and Kolene Steels for under $100. And a Transgo valve body reprogram kit for around $60 if I remember right, CRS sometimes...
For the Cummins I think you really need the 4 spd auto. With the 727 the engine runs too high rpm even with the 3.07 gears and tall tires, and as most already know the 3.07 axle is a throw away if something bad happens inside.
Old Dec 2, 2006 | 04:49 AM
corn binder's Avatar
trans
hey, i need a 727 for my 91 CTD, i also need a 5 spd. for my 90 CTD i just bought. how much are good 5 spd's going for these days? let me know, pete
Old Dec 2, 2006 | 06:47 AM
EClancy's Avatar
Hmmmmm, i wish i could even find one
Old Dec 2, 2006 | 08:11 AM
Rauschbo's Avatar
....I found a few 727's for sale, ranging from $2.3mil to $10mil....(aircraftbargains.com)
Old Dec 2, 2006 | 08:23 AM
DODGE 92's Avatar
tranny
how much is a core 727 with od worth
the reverse band is stripped
hope this dose not sound too much like a clasified
Ggg
Jul 12, 2005 10:31 PM
pwrtripls1
Jun 6, 2005 06:14 AM
Ggg
Jun 3, 2005 07:14 AM
67HotRod
Mar 4, 2005 07:50 AM
Jim Lane
Nov 28, 2004 02:45 AM
