Weight of a Getrag
Old Apr 24, 2008 | 05:09 PM
79_fummins's Avatar
Weight of a Getrag
How much does a getrag with no bell housing weigh?
Old Apr 24, 2008 | 05:23 PM
Around 350 lbs is my guess.
Old Apr 24, 2008 | 05:55 PM
taterfarm's Avatar
not too much carying it into your second floor apartment in several pieces......
but it is real heavy coming back out after the reuild.
Old Apr 24, 2008 | 06:27 PM
bgilbert's Avatar
Ah c'mon Dave, no way. I would guess about 180, no more than 200. 350 is getting up in the nv5600 range iirc. It can be 'somewhat' easily moved about, but much easier on the back with a helper.
Old Apr 24, 2008 | 06:51 PM
MoparMarv's Avatar
HEAVY!!!!!! its a 2 person job moving it. Or atleast that would make it far less painful. I had to scoot it across the yard about 30 feet by myself. my guess is about the 150-180 mark. I had to lift it back on the trans jack once it was under the truck. Rough!
Old Apr 24, 2008 | 07:04 PM
tboling's Avatar
Not really sure on the weight but I put mine in buy myself 3 times I used a trans jack and a cherry picker to get it off the truck.
Old Apr 24, 2008 | 07:18 PM
scottsjeeprolet's Avatar
I weighted a 5600 and it was 350#.
Old Apr 24, 2008 | 07:27 PM
taterfarm's Avatar
Originally Posted by MoparMarv
my guess is about the 150-180 mark. !
I only weigh 140, and I made it down the stairs with it, so that is probably about right.
Old Apr 24, 2008 | 09:25 PM
Alwaysworking's Avatar
alwaysonDTR
if you took it in the apartment to rebuild it where did you wash the parts?
Old Apr 24, 2008 | 09:37 PM
taterfarm's Avatar
I had it apart and cleaned already at home in the garage, then reassembled it on the coffee table at my apartment when the shim kit finally arrived..... finding the shim kit was the hardest part of the rebuild.
Old Apr 24, 2008 | 09:54 PM
alwaysonDTR
what kind of coffee table was that?
Old Apr 24, 2008 | 10:01 PM
taterfarm's Avatar
yeah for some reason the legs all loose now.
But it worked good and it was easy to find then little ***** and springs on the clean floor.
Old Apr 24, 2008 | 10:18 PM
Hot Dawg's Avatar
I'd say it weighs about 150 lbs, its purty easy to move with 2 peeps.
Old Apr 24, 2008 | 10:22 PM
torquefan's Avatar
Must be a single guy.
Old Apr 24, 2008 | 10:42 PM
taterfarm's Avatar
Believe it or not no. but when she moved in I got rid of the tire stacks for end tables and foot rests
Most days she likes the truck almost as much as I do, and thank God for that.
John Marshe
Aug 14, 2020 09:00 PM
bryson711
Sep 5, 2013 08:49 PM
Purplezr2
Jul 25, 2011 04:31 PM
j28s
May 25, 2003 11:13 PM
COHUTTA MNT KID
Oct 12, 2002 08:17 PM
