Water temp. Gauge
Old 08-09-2011, 03:30 PM
Water temp. Gauge
Anyone know the thread size on the Plug that is just past the thermostat?
I got a water temp. gauge, and it came with a 1/8 NPT sensor....and it's like half the size of the plug that is in the engine LOL....It appears to be the same thread size as the Factory In Dash water temp sensor spot that is on the back of the block on driver side.....However no parts houses list the specs on that sender.
Brandon
Old 08-09-2011, 03:33 PM
Onemoparnut's Avatar
Looks like 3/8 npt to me.
Old 08-09-2011, 03:51 PM
Trebor's Avatar
Try a 1/2" x 1/8" NPT threaded bushing from your local hardware store. Getting a brass one could be a plus.
Hey thanks man!!! we should hangout sometime, I live in south jersey too!!!
Old 08-09-2011, 03:54 PM
I don't hang with people who drive smelly diesel trucks sorry. Lol
Old 08-09-2011, 03:59 PM
Why are you putting another temp guage in?
Old 08-09-2011, 04:00 PM
bill are you sure you don't mean 3/4 pipe? 3/8 Looks way too small.....
Now Trebor is saying 1/2....Lol guess I will just have to guess and check.
Old 08-09-2011, 04:01 PM
it's on my buddie's 90, his factory gauge doesn't work and he got the Glowshift 3 N 1 gauge like Joe's has......the only gauge in it not hooked up is the Water temp.
Now that I think about it, It would be better to put it in place of the Stock temp. sensor since thats in the water jacket, and it doesn't work anyways....
Old 08-09-2011, 04:02 PM
Might be 1/2 but I know it ain't 3/4
Old 08-09-2011, 05:27 PM
THEBIGBULLY's Avatar
I stuck mine in behind the throttle linkage bracket. The plug is right up under the intake and you have to lie on your belly from the passenger side and look up underneath to see it. My Autotemp fit right into it.
You don't get to know my name tho' as I don't want to be the focal point of all the swearing once you try to install it there!! (not a fun time)
I only found it as I had the head off and went "Hmmmmm" where did you come from.
It's the perfect length for the wire to reach as well and looks nice and neat once installed.
Good luck.
Old 08-09-2011, 05:31 PM
CaptainChrysler's Avatar
The one by the t-stat is 1/2" NPT, the factory temp sender is 3/4"NPT.
Old 08-09-2011, 11:06 PM
Thanks Captain
mar67655
03-21-2009 05:35 AM
rbrettctd
06-29-2007 04:29 PM
rbrettctd
06-16-2007 10:10 PM
drschumm
01-20-2007 10:27 AM
Tuckerdee
07-26-2006 04:26 PM
Quick Reply: Water temp. Gauge
