water injection <which brand>
Old Jul 27, 2008 | 11:20 PM
O.T's Avatar
O.T
Looking into a water injection kit....a couple questions.
Is high pump pressure a key, some are 150psi--220psi and then Scheids at 800~.
If I wanted this only for security on a big blast what would I need. I'm not pulling or drag racing.
I've looked at Cooling mist/ATS/Snow...
Rob
Old Jul 28, 2008 | 01:27 AM
White97GTVert's Avatar
Devilsown...
http://www.alcohol-injection.com/
Old Jul 28, 2008 | 06:03 AM
Rpainter's Avatar
Originally Posted by White97GTVert
I second this kit great kit and you can adjust it in the cab
Old Jul 28, 2008 | 09:09 AM
mulisha's Avatar
if you are doing this for just an egt issue, and dont tow. you gotta go with the snow kit, shied's is the best by far. but thats for pulling.and its alot of money.
Old Jul 28, 2008 | 10:19 AM
cquestad's Avatar
I think the new Cooling mist with high flow 200 psi pumps...
They one with the controller can be set up to do ANYTHING... Five pumps evern!
Old Jul 28, 2008 | 11:44 AM
matego's Avatar
madhat's monkey boy...
You can crank them up to 220PSI. I have the varicool and it has software and a USB port to make up to 10 custom maps. It can be changed from 10-100% duty cycle, low boost activation and max spray setting.
BTW, Coolingmist has a lifetime warranty and Larry here can hook you up.
FordTrax
May 27, 2014 01:52 AM
Opus
Mar 14, 2011 01:12 PM
jlipskoc
Oct 6, 2009 05:29 AM
jdpiii
Jun 19, 2008 07:34 AM
dodgezilla04
15
Jul 14, 2007 10:01 PM
