Wanting to run two inline push pumps
Old 12-16-2004, 10:14 AM
Mark Thomas's Avatar
Question is: I have two carter pumps and can I run both of them on the stock wiring harness or do I nede to run one off the stock harness and the other off a battery with a relay, what would be the best way to do this so they both come on with the ignition?
Old 12-16-2004, 10:25 AM
banshee's Avatar
I run two... the stock one in the stock location fired by the stock harness, and a Holley Blue behind it wired through a relay that is triggered by the signal from the stock harness. You might be able to run both off the stock harness, but the stock wire is pretty small... 18 gauge if I remember right. I generally use the liftpump pigtail from Cummins as a spacer between the stock plugs so I can solder everything together off the truck and then just plug it in.
John
Old 12-16-2004, 12:58 PM
cquestad's Avatar
Banshee,
You pump through the stock lift pump...how long has your Holley Blue lasted and what fuel pressures do you see?
Thanks!
Old 12-16-2004, 01:07 PM
banshee's Avatar
cquestad,
Yeah, I go right through the stocker. The blue has been pushing into it for 9 months now and hasn't faltered a lick. With the cold weather I'm seeing almost 28psi at idle and it drops to about 14 at WOT. Cruise pressures are generally 24-25 psi.
John
Old 12-16-2004, 01:11 PM
Aer you using the summit racing relay setup?
Old 12-16-2004, 01:26 PM
banshee's Avatar
Mark,
I just have a 30A relay I got from the tech at the local Dodge dealership. I belieive it's a headlight relay that he had laying around. I've had it since I put a pusher on my '01. I installed a pump on another guy's (Goodys1ton) truck using the painless wiring relay that he got through summit. You should be able to get a regular 4 post 20A or 30A relay from any auto parts store though.
John
Old 12-16-2004, 01:31 PM
cquestad's Avatar
Stock lines too Banshee?
Does the 20 or 30 amp part matter?
Old 12-16-2004, 01:49 PM
banshee's Avatar
cquestad,
I'm stock coming out of the tank and forward until the stock line comes out from behind the tank... basically just rear of the transmission crossmember. From there I used a hard tube adapter to convert to -6AN Stainless braided lines. I went from there to the blue, from the blue to the stock LP, and from the filter canister to the CP3. I have a parts list of all the necessary fittings if you guys are interested.
Mark,
It doesn't matter as long as the pump doesn't pull more current than the relay is rated for. On a stock type carter or the Holleys you'll be just fine with a 20A relay as they will only pull 3-5 amps. Big pumps, like the PEs I used to run, would pull a ton. It is a good practice to install a fuse on the battery positive side of the relay to protect the relay itself as well as the wires from too much current draw. Again on my '01, I had the 30A relay and had a problem with the PE pumps blowing 25A fuses! For that pump, though, a 20A will be sufficient.
John
Old 12-16-2004, 02:01 PM
Thankyou so much for the info, I will do this thing monday!
Old 12-16-2004, 09:12 PM
Well looks like two options for a relay kit, Auto zone wants 30 bucks for a painless kit(p/n #50102) and summit wants 26 bucks for the summit kit (p/n # prf-50102)
coon-dog7070
08-13-2009 10:45 PM
2500Ram
10-21-2007 05:06 PM
Gambino-01
16
04-28-2006 06:54 AM
Javahjoeo
03-28-2006 07:57 PM
turbo dreams
04-23-2005 10:03 AM
Quick Reply: Wanting to run two inline push pumps
