i want the door buzzer gone!
Old 03-28-2006, 04:10 PM
mr T's Avatar
alright ...i wanna be able to have the doors wide open without draining any battery...i dont wanna see the dome light and i don't wanna hear the door buzzer....where do i begin?
Old 03-28-2006, 04:20 PM
Dusty Ratcliff's Avatar
there are some door pins that are located towards the front of the doors, they're actually mounted to the cab, but w/the doors open you can push the buttons & the buzzer/lights will go out, you can pull the pin/housing out of the cab & just unplug the wires that go into it & then you'll be able to open the doors w/out the buzzer or lights & if you ever want them back all u have to do is plug them back up, & I just used some pliers/screwdriver to pop mine out, hope this helps, Dusty
Old 03-28-2006, 04:26 PM
StrokeThis2500's Avatar
hey easy way open the fuse door on the side by the driver door and theres a little black box pull it out or away it will stop busing
Old 03-28-2006, 05:18 PM
mr T's Avatar
thank u very much boys...now i can clean the truck in peace and air it out when i go camping
displacedtexan's Avatar
I have in the past wired the door switch up to a toggle, so I can still have the dome on with the door, but also leave the door open with out draining my battery. It was pretty easy, just insert the switch inline with the existing one, and mount it in the kick panel.
Old 03-28-2006, 07:35 PM
JKM
JKM's Avatar
Just don't do what i did... wedge a bolt in between the door , and the switch , to hold it pressed in with the door open, while installing your gauges , then , after a few hours , forget the bolt and close the door... I need a new door switch
MtnDodge
04-10-2012 12:32 PM
cbrahs
11-01-2011 11:00 AM
serious
09-02-2010 03:19 AM
jmccart
01-25-2007 09:58 PM
dieselcrazy
01-06-2005 11:10 AM
Quick Reply: i want the door buzzer gone!
