Walbro 392 Question
Old Jan 30, 2007 | 01:10 PM
HiJenks's Avatar
Thumbs down Walbro 392 Question
I am thinking of installing the 392 on my truck and have a few questions.
Has anyone installed one with auxillary fuel tanks?
Mine feeds thru an electrical switching valve that also switches the return lines to the proper tank.
The only diagram I have seen shows the bypass connected to the fuel tank over flow line.
Thanks for any info
Harold
Old Jan 30, 2007 | 02:55 PM
dieselrob's Avatar
How big are the return lines now? You will need a 3/8 return off the walbro regulator. These pumps more a ton of fuel. If the returns are big enough you should be able to just plumb it in befor the switch valve so it still works. I have my return in my filler neck, so when i fuel up i have to shut down cause the return is moving so much fuel it backs up the pump nozzle and gives you a shower. Trust me i did 3 times till i figured out what was happening .
Old Jan 30, 2007 | 07:19 PM
HiJenks's Avatar
I think the return line is 5/16, stock size, I can probably go to bigger lines from the tap point to the valve and then to the tanks.
Thanks, Dieselrob
Harold
sheriffav8r
May 23, 2008 06:38 AM
skymiles
Dec 20, 2006 08:02 PM
Austin'sDodge
22
Jul 30, 2006 09:31 PM
streetsmoker
24
May 7, 2006 12:26 AM
Dodge Demon
Feb 27, 2006 06:47 PM
