Valve springs replaced??
Old Dec 8, 2007 | 12:39 PM
Tron's Avatar
I have a Pac-brake exhaust brake on my truck that I am going to remove. (It's already spoken for)
Just wondering how I can tell if my valve springs were changed and which ones? Im assuming the exhaust springs.
My buddy wants to put it on his truck. Would he need to change his valve springs?
Old Dec 8, 2007 | 01:20 PM
BC847's Avatar
1st Generation Admin
It's common for the exhaust valve springs to be upgraded to the so called 60# version when running an exhaust brake.
The Cummins 60# spring will look barrel shaped when compared to stock. It may also have a white stripe of paint down its side.
Here's a thread that goes through the typical valve spring swap-out. ~ https://www.dieseltruckresource.com/...d.php?t=171288
Hope this helps. :
Old Dec 8, 2007 | 03:14 PM
Tron's Avatar
Thanks BC847.
If there's anybody else that can help please do.
Old Dec 9, 2007 | 12:01 AM
Shadetree Ltd's Avatar
How well does an exhaust brake work on our non lock up auto? I was told that it would be a waste.
Old Dec 9, 2007 | 10:37 AM
Hawthorne's Avatar
If your buddy has a 5 speed then he'll want to upgrade his valve springs. With my BD brake the instructions are to set it for 8-12 lbs. brake pressure at idle with the stock springs, and 20-25 lbs. with the 60# springs. On a friends CTD w/o the heavy springs I didn't think the exhaust brake was doing anything. No experience with what they are like in the auto tran.
Andrew
Old Dec 9, 2007 | 10:44 AM
gomerpile's Avatar
do heavy duty springs have anything to do with performance, i mean just the springs, or are they just for higher RPM's and e-brakes?
Old Dec 9, 2007 | 01:09 PM
Tron's Avatar
Its on my auto right now and does nothing. Thats why im getting rid of it and to get rid of the stupid flap in the middle of the exhaust flow right off the turbo. Waist of money on a auto unless lock-up or low stall converter.
Jordan5687
Jan 29, 2015 10:32 AM
53 willys
23
May 19, 2008 06:14 PM
12valve
Mar 11, 2008 10:57 AM
95turbo4wd
Dec 12, 2007 05:59 PM
bigred496
Oct 22, 2004 07:16 PM
