Valve Cover Removal
Old 08-25-2011, 03:26 PM
01RAMer's Avatar
Valve Cover Removal
Looking to adjust the valves. Is there enough room to pull the valve cover, or do you have to do something special? Doesn't look like there is enough room above the cover in the back.
Old 08-25-2011, 03:28 PM
Doj Dewd's Avatar
it will go, but you will curse and swear until you figure out the right angles!
you can also cut out some insulation above it to make it easier. also, clean the surrounding area good and knock off any loose debris in the nearby vicinity - you don't want to knock it off and have it fall into the head!
Old 08-25-2011, 04:31 PM
1-5-3-6-2-4's Avatar
Iirc you rock it to the passenger side and slide all the way out forward. Don't worry about the firewall you won't hurt it.
Sent from my Desire HD using Tapatalk
Old 08-26-2011, 10:25 PM
Homestead's Avatar
It's a toss up to roll it over to the passenger or drivers side and slide it out.
I find it easier personally to roll it onto the drivers side and slide it towards the front of the truck. It doesn't look like it, but there is enough room.
Jeff
Old 08-27-2011, 04:02 AM
dodgeguy71's Avatar
It's real easy, takes about 5 minutes to get off the bolts and have it on the ground.
Old 08-29-2011, 11:57 AM
01RAMer's Avatar
In rolling it toward the passinger side, does the turbo get in the way? I sounds like I won't have to take anything else apart to remove it.
tool
01-07-2007 12:47 PM
displacedtexan
17
12-07-2006 09:13 PM
cat1713
09-19-2006 04:34 AM
Nate-03 D
02-24-2006 02:26 PM
suzukiZrider
01-13-2005 08:20 PM
Quick Reply: Valve Cover Removal
