Valve Cover Removal
Old Aug 25, 2011 | 03:26 PM
01RAMer's Avatar
Valve Cover Removal
Looking to adjust the valves. Is there enough room to pull the valve cover, or do you have to do something special? Doesn't look like there is enough room above the cover in the back.
Old Aug 25, 2011 | 03:28 PM
Doj Dewd's Avatar
it will go, but you will curse and swear until you figure out the right angles!
you can also cut out some insulation above it to make it easier. also, clean the surrounding area good and knock off any loose debris in the nearby vicinity - you don't want to knock it off and have it fall into the head!
Old Aug 25, 2011 | 04:31 PM
1-5-3-6-2-4's Avatar
Iirc you rock it to the passenger side and slide all the way out forward. Don't worry about the firewall you won't hurt it.
Sent from my Desire HD using Tapatalk
Old Aug 26, 2011 | 10:25 PM
Homestead's Avatar
It's a toss up to roll it over to the passenger or drivers side and slide it out.
I find it easier personally to roll it onto the drivers side and slide it towards the front of the truck. It doesn't look like it, but there is enough room.
Jeff
Old Aug 27, 2011 | 04:02 AM
dodgeguy71's Avatar
It's real easy, takes about 5 minutes to get off the bolts and have it on the ground.
Old Aug 29, 2011 | 11:57 AM
01RAMer's Avatar
In rolling it toward the passinger side, does the turbo get in the way? I sounds like I won't have to take anything else apart to remove it.
tool
Jan 7, 2007 12:47 PM
displacedtexan
17
Dec 7, 2006 09:13 PM
cat1713
Sep 19, 2006 04:34 AM
Nate-03 D
Feb 24, 2006 02:26 PM
suzukiZrider
Jan 13, 2005 08:20 PM
