Valve adjustment.
Old Apr 4, 2005 | 06:22 PM
edwinsmith's Avatar
Valve adjustment.
Since it doesn't look like my valve covers have ever been off, I need to adjust my valvelash. What's the best way to get the engine to TDC? I know you have to push in the timing pin but I assume you don't do it by bumping the starter.
Edwin
Old Apr 4, 2005 | 06:58 PM
bmoeller's Avatar
You can turn the engine by turning the Alternator pulley, or purchase a barring tool.
http://dodgeram.org/tech/dsl/valve_adj/12_valve.html
Old Apr 4, 2005 | 07:13 PM
edwinsmith's Avatar
Great detailed instructions. Thanks!
Old Apr 4, 2005 | 10:27 PM
59FORD's Avatar
EXTREME CAUTION!
with the push-pin it's plastic and will shear off the tip
if you have too much pressure and rotate the engine too quick.
Old Apr 4, 2005 | 10:32 PM
edwinsmith's Avatar
Yeah, I read that part. Since it would require a second person to push in the pin I figured I'd use the alternate method of turning till #6 is at crossover for #1 TDC and vice-versa. The valves don't require the exactitude of the injector pump for TDC.
Edwin
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
