Upgrading fuel line on 12v
Old 04-28-2004, 03:30 PM
1ST CUMNZ's Avatar
Is it worth while to up grade to a 1/2" inlet and a 3/8" return line on a 12v.
Old 04-28-2004, 03:49 PM
Jim Fulmer's Avatar
Nope, waste of money if you ask me unless you are real high in power.
Jim
Old 04-28-2004, 06:47 PM
infidel's Avatar
I did the math once with a pipe flow rate chart, with the stock hose setup you would have to be getting less than 1 mile per gallon at 60 mph to have restriction. Reversed math gives a maximum speed of 280 mph at 10 mpg before restriction takes effect.
What a pain if you could go 280 mph but had to fill up every 35 miles.
Old 04-28-2004, 07:18 PM
banshee's Avatar
Check your fuel pressure while at WOT. Unless you're pulling it down (it takes a hot pump to do that) you're fine. IT should be in the 30-35 psi range.
John
Old 04-28-2004, 10:08 PM
Jim Fulmer's Avatar
Remember on the fuel calculations that your now figuring in what the truck is doing, you have to push fuel forward as it's trying to push backwars from the truck being forced forward.
So here is some math for you, with my stock fuels system I can pull it down from 33 psi to 5 psi, now at the flip of a switch I'm at 50 and pull it down to 30-32, If I start racing then I'll add a second pump on the aux system, what's nice is I still have the total stock system and everything works, best of both worlds.
Jim
Old 04-29-2004, 02:41 AM
infidel's Avatar
Jim, in case you haven't already done so...
Some folks who have added an aux pump towards the tank have had the fuel heater leak badly.
It's built for suction, not pressure.
Old 04-29-2004, 10:27 AM
Jim Fulmer's Avatar
Good to know info for this thread!
On the Hasiley's system it uses a different pickup, pump and filter and goes into the banjo bolt at the pump, I'm sure it back pressures some to the stock system but it is rarely on, when I get ready to make a run I'll flip it on, right after the run I turn it back off. I have left it on accidently for say 30 minutes and it wasn't even warm.
Jim
DENVERDODGE04
12-19-2008 05:31 PM
DENVERDODGE04
12-17-2008 06:46 PM
Red3quarter
11-28-2006 11:30 PM
baersmokers
11-20-2006 09:49 PM
csramsey640
09-03-2006 07:10 AM
Quick Reply: Upgrading fuel line on 12v
