Unhooking The Map Sensor
Old 04-02-2006, 08:44 PM
edy
edy's Avatar
If i unhook the map sensor on my 24 valve will it make more smoke just so i can show off around my buddies.
Old 04-02-2006, 08:49 PM
Dusty Ratcliff's Avatar
yep, sure will, give it a try, you'll love it, Dusty
Old 04-02-2006, 08:55 PM
in2gpn's Avatar
un hook it from the factiry harness or the harness that comes with your favorite fueling box harness??
Old 04-02-2006, 09:51 PM
iker42's Avatar
Does Unplugging it have any downfalls?
Old 04-02-2006, 10:05 PM
oestreich84's Avatar
If you un-plug it without a comp, your check engine light will come on. There might be some other boxes that the check engine light wont come on with, but I dont know for sure. I unplugged it when I had my van aaken box and the light came on, but the truck was much more responsive. I have it unplugged now with my comp and it can be kinda hard to take off without leaving a cloud behind. Most of that is probably the way I drive though I unplugged it from the boost sensor, leaving the comp still connected, that way there is no check engine light.
Old 04-02-2006, 10:09 PM
iker42's Avatar
so w/o the box, is there any bad side affects?
Old 04-02-2006, 10:29 PM
I don't know for sure, but I don't think there would be any effects. The computer fuels according to boost levels. So without a boost fooler, and the boost sensor unplugged, the truck might go into a "limp" mode. There is only one way to find out for sure, go out and unplug it! If it has no effect, just plug it back in and everything will be back to normal. After a couple key cycles the check engine light will go off on it's own. At least it did when I had mine unplugged with the van aaken.
Old 04-03-2006, 02:22 AM
ratat98's Avatar
Without a box, nothing happens except for the check engine light coming on. I tried this a few months ago, and it just acted a little sluggish without any smoke so you have to have a boost fooler to make it smoke and give it power from what I understand.
Old 04-10-2006, 12:12 PM
singleturnout's Avatar
unhooked my map today and wowwwwwwwww! it really rolls the coal now
Old 04-10-2006, 04:41 PM
I SPEED's Avatar
There is more power to be had by unplugging the Map?
Old 04-10-2006, 05:55 PM
it feels more responsive i dont know if it adds more power but boy does it smoke
Old 04-10-2006, 06:00 PM
Administrator / Scooter Bum
Shovelhead's Avatar
At the current price of diesel fuel, sending all that partially burned fuel out the tailpipe just to "impress' someone seems like a waste.
Old 04-10-2006, 06:06 PM
90% of us one here have done things to our trucks to imprees others
Old 04-10-2006, 07:19 PM
STACKED's Avatar
if you have a box do you just unhook it from the block or the box or does it matter, just anywhere.
Old 04-10-2006, 07:39 PM
Registered
blackdiesel's Avatar
you have to have a box and you have to unhook it from the block
Quick Reply: Unhooking The Map Sensor
