Ultimate HD transmission
Old 11-10-2009, 08:20 PM
RAMRODD's Avatar
Tranny went out on my 06 dodge had a full load of hay and about the time the boost hit 60psi, fourth gear let go.
I will take my tranny apart in the next day or 2 to see if it is repairable but I assume it is not. I could just replace it with another G56 but I prefer to put something in a little more HD. NV5600 really isn't a option for me since I broke one of those in the past. Actually the G56 lasted a extra 60K.
I am interested in going with a Eaton Fuller 6 speed FSO-8406A rated at 860tq. Or would consider any transmission that would work. I also need to be able to make this work with 4 wheel drive!!!
Has anyone done any research or know of a place or a person that does this kind of work????
File Type: pdf
Old 11-10-2009, 09:35 PM
bansh-eman's Avatar
How much are you looking to spend? You could opt for an allison but not sure it would be much differant then what you got? Maybe a Georend?
Old 11-10-2009, 10:06 PM
cbrahs's Avatar
His is a manual tranny.
I have heard of guys installing 10 speeds into their trucks. My buddy in Texas is looking at a 2nd gen right now that is for sale with a 10 speed installed. I told him to send me pics asap but he has not been able to get ahold of the guy.
Old 11-10-2009, 10:12 PM
Asher's Avatar
Well if you gonna go a route like this, why not go with a unsyncro'd 7-speed? And since this will be a custom job and you need 4WD, then make yourself a divorced transfercase set up. This way you can pick and choose your tranny and not limit yourself to a special tail shaft design and your transfercase will be all gear driven and cast iron.
Old 11-10-2009, 10:23 PM
cbrahs's Avatar
http://www.sanco-bg.com/Conversion_NV5600.htm
Old 11-10-2009, 11:18 PM
RAMRODD's Avatar
Originally Posted by cbrahs;2625921
[URL
http://www.sanco-bg.com/Conversion_NV5600.htm[/url]
Nice find!! same transmission I was thinking of
Old 11-10-2009, 11:21 PM
cbrahs's Avatar
sweet. I helped someone today!
Old 11-10-2009, 11:24 PM
bansh-eman's Avatar
It never even crossed my mind that you wanted a manual That video is way too much shifting lol
Old 11-11-2009, 07:45 AM
XLR8R's Avatar
Pretty cool - get to play Big Rig & still use the drive-through...
Old 11-11-2009, 06:51 PM
elirandolph's Avatar
That would be too cool!
Old 11-12-2009, 07:59 PM
cromulius's Avatar
Personally I would rather drop my truck off for a new tranny every 50k than shift that much.
Old 11-12-2009, 09:59 PM
RAMRODD's Avatar
Finally got time to pull the tranny all the way. Doesn't look bad from what I can see. I have 2 gears that need to be replaced. I don't have the case split all the way. Darn thing just wont pop open. So their still could be more wrong.
If I can fix it cheap thats what I will do for now.
Old 11-13-2009, 12:09 PM
DTR 1st Sergeant
soulezoo's Avatar
That 10 sped brings back nightmares of when I was learning to drive big rigs....
Hated all that shifting... of course I learned on 13 and 15 speeds behind a cummins 350 and a Marmon v-12.
Battering Ram
15
02-01-2011 02:46 PM
Snapoff
18
04-02-2008 01:08 PM
cquestad
24
11-20-2007 11:15 AM
99cumminsdude4
05-07-2003 01:45 PM
Quick Reply: Ultimate HD transmission
