twin turbo question
Old Apr 23, 2009 | 10:33 PM
jcmoyer2004's Avatar
twin turbo question
i was wondering if anyone had done a set of twins on a non i/c truck. if so, how well do they work, how much does it bring down egts and what does it do to the sound of the exhaust. forgive my ignorance but i'm not to familiar with twins. i did my upgrade, i just really want to do twins for the heck of it HAHA
Old Apr 24, 2009 | 12:21 AM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
i have ben talking with a VERY smart person and if i can do it cheep enough
were talking triplets!!!!!!! talk about unique
Old Apr 24, 2009 | 12:26 AM
pulltilbroke's Avatar
Best Paint (Getrag category)
Search for captainchryslers twins thread, I think he's got some video of his truck with twins also
BigErksG2's Avatar
twins will be really effective on lowering egt's and making more power even without an intercooler.
Old Apr 24, 2009 | 05:44 PM
CaptainChrysler's Avatar
My brother and I build a set for our '89. It is totally worth it. Pulls like a crazy at 60 psi.
It made the exhaust pretty quiet, even with the hood stack. You can really hear it when the big one comes alive.
As far as EGT drop I really can't say cause we never had a pyro before. I don't believe it has even been to 1400* since putting them on. The EDM's ought to change that.
https://www.dieseltruckresource.com/...d.php?t=222129
Old Apr 24, 2009 | 05:58 PM
pwrtripls1's Avatar
most high HP pulling trucks and 12v drag trucks use twins without an IC. Of course they run w/m though. lol It would drop your EGT's but would also run more boost so you'd need some good tight head bolts or studs.
Old Apr 24, 2009 | 07:23 PM
You'll need head work,
If the big boy is putting otu 60psi like most, your stock headgasket will last like 5 seconds. lol
Old Apr 24, 2009 | 07:29 PM
peobryant's Avatar
I know a guy that ran his twins, with 60+psi, for months with a stock gasket, and only a retourque. I wouldn't try my luck though.
Old Apr 25, 2009 | 09:47 AM
pwrtripls1's Avatar
he just replaced his head gasket but might want to get some head bolts just to hold it together.
Old Apr 25, 2009 | 02:55 PM
well i just got the stacks on and will be posting pics hopefully soon. the hg is only a few months old so yeah, headstuds will be a definate upgrade before hand. just have to figure out how to build them and what are the best turbos to use for a daily driving type set up.
Old Apr 25, 2009 | 03:40 PM
93Fury's Avatar
You'll have alot of different responses to that question, most people will say either a H1C or HX35 over a 3B. I haven't built my own yet but drove a truck with that set up and then they got swapped for a modded S300 over a S480. I personally like the 300/480 combo, didn't do the greatest towing though but man was it fun to drive.
Old Apr 25, 2009 | 05:54 PM
Greed 93's Avatar
I would not go with a ht3b if you can they are reverse rotation uniquie flange also not many upgrages ethier just my 2 cents.
Old Apr 28, 2009 | 08:01 AM
pwrtripls1's Avatar
just keep your turbo you have but get a W/G housing on it, and get a S300 low pressure side. It wouldn't cost a ton of money and would spool really nice. No reason to go with a huge low psi turbo that will spool slow if you dont plan on making 500+hp. Your GDS III and S300 will run 400-450whp easily at a safe EGT.
Hurry up with the pics, I wanna see the stacks. lol
Old Apr 28, 2009 | 08:24 AM
apwatson50's Avatar
You need bigger than a s300 sized turbo that everyone sells as a single for the primary/bottom/low pressure turbo. I've heard that a K31 waste-gated turbo is a great bottom turbo for a lower hp towing setup.
Old Apr 28, 2009 | 08:55 AM
well i'm sure i'll do much more research before i jump off the deep end and dive into buying a turbo. thanks for all the input, pwrtripls1 i'm sure i'll be calling you for advice and seeing if you want to help build this monstrosity that i have planned oh and i'll get you some pics of the stacks if i don't float away from all this rain
JSCumms2000
13
Sep 24, 2008 05:46 PM
1974d2004x4
13
Oct 17, 2007 07:47 AM
VikingDiesel
116
Aug 2, 2006 05:50 PM
MR HYDROSEED
Nov 15, 2005 11:31 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
