is turbo covered under 100,000
Old 07-24-2007, 04:32 AM
CTD03's Avatar
is the turbo covered as part of the 100,000 engine warrenty?
i sure hope so
thanks
Old 07-24-2007, 05:21 AM
herb's Avatar
pretty sure it is.
Old 07-24-2007, 06:05 AM
CTD03's Avatar
i hope so i dont have the book to read up on it
Old 07-24-2007, 08:15 AM
herb's Avatar
i had one replaced with warranty on my 01
Old 07-24-2007, 08:28 AM
CTD03's Avatar
so they are covered by the 100,000
sweetness thanks
Old 07-25-2007, 08:17 AM
Thomas's Avatar
Look in the 2003 Ram Warranty Information Booklet. The turbocharger housing and internal parts are covered under the Basic Limited Warranty, the Powertrain Limited Warranty, and the Cummins Diesel Engine Limited Warranty.
-Thomas
Old 07-25-2007, 08:32 AM
CTD03's Avatar
well what is says is that it is covered so i guess i am good
wish i would have read the darn book about the water pump
ggggggrrrrrr on my part
thanks for the info
Old 07-25-2007, 11:00 AM
CTD03's Avatar
i was wondering about my turbo i checked the front wheel seems fine
my friend was behing my truck at night and said it was blowing sparks out
is this turbo failure
i checked it front side of the turbo and it did seems way tighter to spin but that front wheel had no play in it
any help please
Old 07-25-2007, 11:15 AM
jrs_dodge_diesel's Avatar
Shooting sparks out the pipe could be a plethora of things. Not just the turbo. Since you have an 03 you're truck won't regen (particulate trap) like the 07 and newer trucks. Could be soot particles getting burned off, excess fuel going down the pipe. If the turbo (the exhaust turbine in this case) were hitting the housing you would know it. That would make a loud screech like noise everytime it hit. Since you said the shaft doesn't have much play (normal) I don't suspect that at all.
I see in your sig that you have performance mods. Do you have guages as well?
Old 07-25-2007, 12:23 PM
CTD03's Avatar
Yes i have guages and i do watch the turbo i only have it go past 1500 3 times each time that was long time ago
is there any thing else to look for
i have no muffler or cat on the truck so i didnt think it could build up any thing
so maybe its not hurt
JIT
01-09-2006 05:59 PM
Tommy93w350
06-20-2005 04:51 PM
030303
12-01-2004 06:58 PM
chrismez
11-08-2004 06:38 AM
Commatoze
08-19-2004 04:00 PM
Quick Reply: is turbo covered under 100,000
