Turbo Boost
Old 10-09-2005, 05:11 PM
oscgalis's Avatar
Turbo Boost
Could someone please tell me how much boost should the 2000 24 valve cummins put out?
Old 10-09-2005, 05:52 PM
zukgod1's Avatar
Depends on the mods.
With mine I get about 42 at WOT from a stop but at freeway speeds if I mash er down I can get 50.
I think the stock set up is around 20 PSI.
Old 10-09-2005, 06:07 PM
phox_mulder's Avatar
Yes, it will vary between 19 and 21 for a stock truck.
phox
Old 10-09-2005, 07:11 PM
wildbill040's Avatar
Stock 2nd generation engines are limited to 15-18psi of boost. With an aftermarket control box, you could see as high as 45-50psi in a high setting and a modified elbow on the turbo and/or a modified waste gate. Mind you though, the stock computer is calibrated to work within its programming and will set a "over boost" code every time you do.
Old 10-09-2005, 07:41 PM
oestreich84's Avatar
On the 98-2000's the wastegate is fully open at 19 psi on a stock truck. With just my VA box I can see over 30 psi and with some injectors it is pushing the stock hx35 out of its efficiency range. On the 01 and 02 auto tranny trucks the boost is set at 21 psi, and the 6 speeds are set at 26 psi.
Old 10-10-2005, 08:12 AM
Mopar1973man's Avatar
I'm seeing right around 18-20 PSI for a stock truck with a 5 speed...
97dodgeram2500
11-01-2009 11:51 PM
jcarrillo
07-10-2009 08:24 PM
JSCumms2000
13
09-24-2008 05:46 PM
vwjunkie53
19
11-09-2007 02:27 PM
Bobcat698
18
10-22-2005 12:27 PM
Quick Reply: Turbo Boost
