Turbo boost HELP....pls
Old 05-01-2007, 03:09 AM
Seditious300c's Avatar
i have a 99 dodge ram with 300 hp injectors, industrial injection sho injection pump, 5 inch exhaust, and a new air intake. these parts were all recently put on and now i have an engine code that says something like "boost pressure exceeded" what should i get or what could i do to fix this? and has anyone had this problem and what did you do? thanks for all the help in advance
Old 05-01-2007, 03:15 AM
Jturs's Avatar
Do you have any other mods on the truck? fill in you sig.
Old 05-01-2007, 03:31 AM
Jturs's Avatar
here is what chrysler says
Symptom:
P-0234 TURBO BOOST LIMIT EXCEEDED (OBDII)
When Monitored and Set Condition:
When Monitored: Ignition on.
Set Condition: Engine Speed >2200 RPM, No intake air pressure sensor out of range
DTC’s present.
POSSIBLE CAUSES
WASTEGATE MECHANICAL FAILURE
WASTEGATE STUCK
231
DRIVEABILITY
Old 05-01-2007, 06:03 AM
BCSCUMMINS's Avatar
Are you running any kind of programmer or fuelling box? What code # is it showing?
Old 05-01-2007, 06:23 AM
6WHEELER's Avatar
overboost code, Sounds like you need a boost fooler, or if you have a performance box"edge,tst,etc" the boost fooling part might not be working. what other mods do you have?
Old 05-01-2007, 07:48 PM
i dont remember the exact code and i do have a bully box from bully dog that im going to be hooking up tomorrow. i was thinking that the bully box might fix it
Old 05-01-2007, 07:49 PM
oh yea and by the way the code only comes up when i drive the truck hard, if i just cruise and no peddle to the metal it doesnt come up
Old 05-01-2007, 09:00 PM
pmtg's Avatar
i dont see any gauges listed...could be an expensive mistake to not have them!!
yep, get that bully dog box on there and you wont throw the code anymore.
without the box, driving it hard will raise your boost beyond the factory spec and cause the code.
Old 05-01-2007, 09:29 PM
actually my gauges just showed up today and thanks for the help
iweb
21
06-14-2007 09:00 PM
12VRoush
13
03-14-2007 02:14 PM
Seditious300c
03-08-2007 11:12 AM
Rauschbo
07-20-2005 11:10 AM
Duff
01-31-2004 07:32 PM
Quick Reply: Turbo boost HELP....pls
