TST Power Max 3 and Map Sensor???!
Old Dec 31, 2006 | 10:26 AM
HixDiesel's Avatar
Question TST Power Max 3 and Map Sensor???!
I want to know if I can still run normal without my map sensor I have a TST Powermax 3 , Right now it will barely smoke and I am looking for a cheap solution for the problem without going through another VP44 or lift pump
99 24 Valve, 2nd Auto trans , Power Max 3 , 4 inch down pipe duel Stacks , 4 inch Sky Jacker Suspension, Viper Hood, Tow Mirrors, 3rd Vp44 and Lift pump , 37 inch Goodyear's
Old Dec 31, 2006 | 12:31 PM
BigBlue's Avatar
You need to have the map sensor plugged in on your TST for it to work correctly. You can't disconnect it like you can the Edge Comp. I know I lost a LOT of smoke when I switched from a comp to a TST. I for one was thrilled about that.
Old Dec 31, 2006 | 12:52 PM
HixDiesel's Avatar
Thanks Blue but do you or anyone else know any more cheap ways to smoke ?
Old Dec 31, 2006 | 03:09 PM
displacedtexan's Avatar
Trash bag over your intake...
Constant smoke is bad for the enviroment and our hobby as a whole because of the damadge it does to our image on a whole.
What does your fuel pressure look like, you should have plenty of fuel for somke.
Old Dec 31, 2006 | 07:00 PM
HixDiesel's Avatar
Fuel pressure is a steady 15 lbs until take off it goes down to about 7 i heard anything around 11 is good for a 99 ? idk and as for the environment its already screwed
Old Dec 31, 2006 | 07:07 PM
BigBlue's Avatar
Might be already screwed but since it's the only one we got we need to save it. I'm all for blowing black clouds but I don't run around doing it. I try and drive with as little smoke as humanly possible.
Old Jan 1, 2007 | 03:35 AM
DrDiesel's Avatar
Talking
I hate when my truck smokes. It`s quite, clean and fast.
I had some guy with a 2500 Dodge Ram gas job with loud exhaust, jacked way up and over sized tires pull up next to me at a red light.
Well with all the noise that crap wagon made, I knew exactly what he was up to. He tried to race my Clean, Quite Diesel.
But when the light changed I quietly and cleanly left him behind me...
Old Jan 1, 2007 | 09:43 AM
HixDiesel's Avatar
Well sounds like you have a pretty nice truck , just to be keeping it in silence why not just drive a Honda?
Old Jan 1, 2007 | 11:06 AM
TNfarmboy's Avatar
Agree completely!
Of course there is nothing wrong with having a little fun , but smoking folks in town at intersections is like said above.....not good for our image on a whole and in the end not
Since I put on my Comp I see a little smoke but I don't try to be Cool and smoke people.
Old Jan 1, 2007 | 12:54 PM
BigBlue's Avatar
Some people like to be a sleeper. I through that out the window when I put the stacks on.
Old Jan 1, 2007 | 12:57 PM
HixDiesel's Avatar
Cool
same here especially when I hit the button and back glass slide open I cant even hear my radio and I like it
Old Jan 1, 2007 | 12:58 PM
blackdiesel's Avatar
Registered
doc said i was a sleeper on the other site
most think shes just an ole farm beater........
Old Jan 1, 2007 | 01:02 PM
getblown5.9's Avatar
my trucks a sleeper, its big and slow when i granny shift, and just makes alot of noise while only throwing a slight grey haze like an old worn out farm truck...til some ricer thinks he is gonna beat me to the end of the merge area...thats when all heck breaks loose, smoke pours, turbo roars, tires spin and im slamming gears while the ricer is like
Old Jan 1, 2007 | 01:18 PM
BigBlue's Avatar
Yup. Sounds about right. Some poor crown vic tried that on me the other night.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
Ph4tty
Oct 19, 2006 11:21 AM
strokethis600
Nov 10, 2005 05:09 PM
Zino
Aug 15, 2003 10:14 PM
