Truck wont crank over with key but will with rigged up switch
Old 03-11-2007, 02:01 PM
Dufrain's Avatar
My truck wont crank over with the key.Someone has rigged in a push button.They cut the white wire on the fuel shutoff solenoid and ran a new wire .What should I replace to get this thing fixed right.My solenoid has to be lifted also to get it in run position.It shuts off ok.thanx
Old 03-11-2007, 02:49 PM
clutch1's Avatar
it wont crank or it will, but not start. might have to check voltage at the solenoid to see what your gettin or not gettin. ones hold in voltage the other is pull in voltage.
Old 03-11-2007, 02:50 PM
TIMMY22's Avatar
sounds like the solenoid "pull" was down probably from a bad relay or a corroded wire. Somebody hacked something. check to see where the wire they spliced into the white wire connects.
Old 03-11-2007, 03:04 PM
Dufrain's Avatar
I hooked the large white wire back together like it was from factory.It is one of the 3 wires in the oval plug that goes to the solenoid.I have 12 volts to the relay on the fire wall.
txhawg
18
07-17-2011 02:46 PM
bigredbrick
04-23-2010 07:30 PM
stealman1
11-09-2007 11:07 AM
12valve@heart
09-08-2006 06:06 PM
JW3
12-26-2005 07:10 PM
Quick Reply: Truck wont crank over with key but will with rigged up switch
