Truck Shakes When Idling
Old 12-06-2004, 09:13 AM
Thats MR Hoss to you buddy!
Hoss's Avatar
On a few occasions....ALWAYS while waiting in the drive thru at the local Whataburger...my truck has started shaking while it sat there idling. It almost feels like a bad motor mount, but I would think if that were the problem then it would ALWAYS do it while idling. It has only done it a few times though and it has only done it at that one place (nothing special about that place). If it does it, I can drive it a bit and then stop and it won't be doing it any more.
Anyone have any idea what might cause it?
Old 12-06-2004, 09:24 AM
sawboywv1's Avatar
Maybe your concrete bedliner is out of balance?
Old 12-06-2004, 10:40 AM
converteddzlr's Avatar
Hmmm, matbe your truck just doesn't have an appetite for Whataburger bio! I had one of those while in Tx a while back and my body shudders just recalling it
Old 12-06-2004, 10:44 AM
jkitterman's Avatar
Air conditioning will cause this as will the engine fan turning on if you are just sitting.
Old 12-06-2004, 02:21 PM
SBishop's Avatar
Hoss,
Your truck is trying to keep you healthy? Don't stop at 'WhatABurger'
Old 12-06-2004, 02:23 PM
Hoss's Avatar
I suppose it COULD be a fan, but I would think it would have done that since day one if that were the case. It just started doing this recently...and it has only done it two or three times. Aside from that, I have literally let it idle for hours during the summer with the A/C running and it never did it then. Only recently...and only at the Whataburger drive through.
What it FEELS like is a bad motor mount, but I would think if that were the case then it would be doing it ANY time it was idling.
Old 12-06-2004, 02:28 PM
SBishop's Avatar
Hoss,
'WhatABurger' aside, I would have to guess a dirty injector.
Old 12-06-2004, 03:32 PM
Hairy1's Avatar
Location: Adirondacks of New York and Daytona Beach FL.
A little fuel conditioner may be needed.....then run the hell out of it
Old 12-06-2004, 04:00 PM
R.M.THOMPSON's Avatar
Check out your engine for a injector that is leaking-by , could be a disaster waiting to happen.Do the math on 750 rpm's divided by 60 then divided by 6 for firings per sec and see if that is the originator frequency thats close to what you are feeling.Not trying to sound like an egghead , but would hate to hear of a piston with a hole burned thru the top..................
Old 12-06-2004, 04:14 PM
sawboywv1's Avatar
Hoss,
How many miles are on your truck?
Have you changed out your fuel filter lately?
You might have a small amount of water in the system.
All this injector talk is really making things alot worse that it is...
most of the injector related issues seam to be with the 04-04.5 units. Mine has 30k on it and everyhthing has been OK with mine.
Old 12-06-2004, 05:45 PM
030303's Avatar
Is the drive thru on a hill? Mine seems to idle different on hills. Mabye binding or starving for fuel?
Old 12-06-2004, 06:59 PM
fahlguy's Avatar
I am with sawboywv1.....I think it has to do with your Concrete bedliner also.
Old 12-06-2004, 08:17 PM
StrokeThisCTD's Avatar
maybe your suspension accidentally flexed like it wasnt supposed to, and screwed the concrete up
Old 12-07-2004, 08:01 AM
JamesP's Avatar
You forgot to divide by 2 since these engines are 4-strokes
Old 12-07-2004, 08:37 AM
Hoss's Avatar
Originally posted by sawboywv1
Hoss,
It has almost 37K miles on it. The fuel filter was changed at 30K miles.
I don't think it is an injector. It has only done it about 4 times over the past four weeks and only for the 2-3 minutes I sat in line in the morning to get a taquito. If it were an injector I would THINK it would be doing it consistently.
Just the same, I'll run some Diesel Kleen through my next few tanks and see if that makes a difference.
Quick Reply: Truck Shakes When Idling
