truck has hickups
Old 03-27-2007, 10:52 AM
smokNjoe's Avatar
truck has hickups
My truck had a few stumbels (dead peddel for a split second) yester day so i took it to my work and scaned it. My ip was reading normal pressuer and fuel pressure is normal. The scanner said that it was low voltage to apps so sould i just replace it or just try to adjust the voltage. I herd that you didnt need to adjust voltage on a manual trans so i dont know what to do. I also dont want to spend the $ on a new apps if i dont have to.
Also i have the abs and brake light on. So i replaced the speed scensor in the rear and still have the lights on and scaner wont pick up what is wrong any ideas.
Old 03-27-2007, 10:44 PM
ramroamer's Avatar
Had a similar problem and it was a bad throttle position sensor. Just an option, truck would do ok, then cut out, then ok.
Old 06-04-2007, 04:08 AM
EverydayDiesel's Avatar
did you ever fix the abs and brake light problem?
I have a similar problem and was throwing P0500 but then I reaplaced the sensor in the rear. No more P0500 but I still have the brake and abs lights on???
tempforce
07-27-2008 08:08 PM
GUMP
05-26-2008 08:26 PM
Redliner
09-23-2007 08:42 AM
jtalaiver
20
06-22-2007 10:36 AM
FDX
01-15-2007 01:47 PM
Quick Reply: truck has hickups
