Trouble shooting a TPS problem
Old Jan 28, 2008 | 10:57 PM
Suneview_Farm's Avatar
Pulled the codes on my truck and it called for a bad TPS...They're $534 and i really dont want to spend that just to find out the sensor is good but a wire is bad. So any pointers on trouble shooting a bad TPS?
COdy
Old Jan 29, 2008 | 08:26 AM
matthopp's Avatar
familiar recent problem for me...if you have access to a computer/scanner, you can monitor the throttle % and voltage and that should give you a pretty good indication. You can also try borrowing one from a friend and see if it makes a difference.
Old Jan 29, 2008 | 09:26 AM
Boilermaker08's Avatar
You might just have to man up and pay for it. I paid $409 for mine from Cummins
Old Jan 29, 2008 | 10:03 AM
can17's Avatar
What kind of symptoms are you seeing other than the code?
Old Jan 29, 2008 | 01:47 PM
I can be goin along and without movin the pedal my rpms will drop to idle and it wont take off until it idles for 2 seconds or so...then i can regain speed again
cody
Old Jan 29, 2008 | 02:01 PM
can17's Avatar
Before you buy a new one, it might not hurt to try this:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Feb 3, 2008 | 08:14 PM
Thanks Can17! Adjusting the voltage did the trick...it was doin it as many as 6 times a day and since I adjusted it it hasnt done it since. The voltage was really low. It was bouncing beween 0.3 and 0.2 on my PowerProbe and the stick on the TPS said 0.488 so I got it advanced to 0.485-0.490.
Thanks Again!
Cody
whosdunit
May 17, 2014 08:54 AM
ArbrnEngr
Apr 13, 2014 03:12 PM
KRB
Jul 18, 2013 08:52 AM
BearKiller
Jul 23, 2007 11:21 PM
apache
Sep 16, 2005 10:32 AM
