Transmission shifting Rough
Old May 11, 2006 | 04:46 PM
running4bhs's Avatar
Ok I need some help guys, my truck is shifting really rough from 1st to second gear and then 2nd to 3 is a little rough, but not as bad. Could this mean I need the bands adjusted, or could it be something else? Thanks everyone
Old May 11, 2006 | 04:52 PM
marine4life's Avatar
shifting rough usually signifies running higher pressure through your valve body. mines shifts hard but i set it like that because of the higher horsepower. you can have the pressure adjusted to your liking, im sure the other guys will add in their .02 cents.
Old May 11, 2006 | 05:02 PM
John Faughn's Avatar
Ya drop the pan , change the filter , then do a flush , maybe take the govenor out and clean , do maitance 1st , then repairs.
How many miles on trans. ?
Old May 11, 2006 | 11:56 PM
Well trans was rebuilt around 170K and im now at 210k so, I have changed the fluid about 8k ago and filter also, wasn't sure how to get all the fluid out of the TQ. I disconnected a oil trans hose by the trans oil cooler and turned the truck on and run it in neutral.
Chass
0
Jun 19, 2011 02:05 PM
2006Mega
Jun 5, 2011 08:19 PM
98 Ram 24V
Dec 24, 2005 10:19 AM
Jmac
Mar 26, 2004 10:31 PM
Mexstan
Mar 31, 2003 02:37 PM
