Transmission oil
Old 04-19-2006, 08:24 AM
Motorpool's Avatar
Transmission oil
I have a 1999 24V five speed and need to know what kind of oil goes in the transmission? The gear box turned over on me and off the jack as I was putting to box back in and I lost almost all of my oil before I noticed it pouring out. For the man who thought I had a clutch problem, you were right, the pilot bearing wore out and the clutch plate was broken and springs flew everywhere when I unbolted the pressure plate. Thanks, please reply so I can get this thing on the road to Illinois. Sonny
Old 04-19-2006, 10:55 AM
HOHN's Avatar
Sonny, you need a heavier oil in the NV4500.
Castrol Syntorque 75w-90 is the spec fluid, but consider some Redline MT-90 (*NOT* the MTL) as well.
Stick with these two. The Castol is the safest, best all around bet.
jh
Old 04-20-2006, 06:07 AM
VADSLRAM's Avatar
You'll find a bunch of people like the synths. I like Amsoil 75-90.
Old 04-20-2006, 06:49 AM
Truckman's Avatar
Talking On the Fill Plug
It should say what type of fluid to put in, on the tag on the tranny Fill Plug Or Owners Manual.
If it's a NV4500 it came with synthetic from the factory.
Old 04-20-2006, 09:23 PM
Yukon Dodge's Avatar
Before you put put that same El Cheapo Mopar pilot needle bearing back in, check out Quad 4X4's sealed ball bearings at http://www.quad4x4.com/Dodge%20Engin..._Pilot_Bearing
Be sure you use the right Amsoil lube for that tranny...there's only one!
ian515
10-16-2007 07:02 PM
TxDiesel007
15
01-18-2006 01:19 PM
Quick Reply: Transmission oil
