tranny temp sender
Old Jun 27, 2005 | 12:57 AM
abbeyinc's Avatar
tranny temp sender
Hello,
I read somewhere - and cannot find it again - that you may install an aftermarket tranny temp sender where the stock one is located as long as you place a resistor in line between the new sender and the factory wire.
True? Close? Dead wrong?
Old Jun 27, 2005 | 02:20 AM
got...DIESEL?'s Avatar
yes....get a 1k ohm resistor from radio shack and put it between the factory temp sender wires, insulate it up and drive away. You will have to also install a bushing adapter to neck the factory pipe bung down to 1/8" NPT. I made sure the probe didn't extend down into the line much and hamper flow....but with the adapter, this doesn't happen anyway.
Old Jun 27, 2005 | 10:44 AM
infidel's Avatar
The resistor trick only works with the RH tranny used until '96, it won't work with your '98 RE since the temp sender is internal to the tranny.
You will have to get an output line for a pre-96 that has a port in it, you don't need to do anything to your stock sender then.
Old Jun 27, 2005 | 01:10 PM
abbeyinc's Avatar
very good. Thanks for the help folks.
Old Jun 27, 2005 | 03:52 PM
I knew bill would speak up...thanks, I only know the RH systems off the top of my head
t-boe
Oct 13, 2007 06:46 PM
Big Smoky
Jun 29, 2007 05:16 PM
AZn8v
Feb 5, 2007 07:52 PM
CAR Hauler
May 26, 2006 08:18 AM
kennedy
Sep 17, 2005 08:05 AM
